Has anyone ever cleaned their headlight lenses?
RangerM
I hit a deer a couple of months ago, taking out my grill and LH headlight.
I now have a new clean LH headlight, and a RH headlight that looks like it has cataracts.
I've read a bit about several solutions to the problem and wanted to see if anyone had any experiences they could provide.
mild rubbing compound and a good polisher do wonders. i wish i had the pics here of a set i did on a Civic not too long ago.
Headlights are plastic. Modern auto clearcoats are urethane which is also basically a plastic. some of the same processes apply to both. You can polish the lenses with a mildly abrasive compound though. you can do it by hand, but im sure if you hit up a local detailing shop, they will be better equipped to do it right, and it wont take long.
I purchased a kit at Auto Zone for around $12.00 that included a buffer that fit into a drill. It worked wonders for me
Follow the directions closely for those auto part store headlamp restoration kits. They really work! A coworker of mine with a 2001 Mazda Tribute recently cleaned her lenses all by herself and they look like brand new. I seen the before and after and it was amazing!
Check out this link:
Headlamp Restoration
Edited by Watchdevil
  • 3 weeks later...
Thanks to all for the suggestions.
I got the lens cleaned up nicely on the outside.
Unfortunately, I guess I didn't realize that after 15 years there would be any discoloration on the inside.
Oh well. Either I'll get a new one, or get over it. There is a marked improvement in the RH headlight performance regardless.
  • 2 years later...
