slortiz1 Posted March 5, 2010 Share Posted March 5, 2010 I have a 2006 Explorer and my RR back up light went out. I replaced this bulb, now my light on the instrument panel tells me "Check RR Lamp". I tried to uninstall and reinstall, but the same results. (using the same new bulb) Can someone help me here? Quote Link to comment Share on other sites More sharing options...
fordtech1 Posted March 5, 2010 Share Posted March 5, 2010 I have a 2006 Explorer and my RR back up light went out. I replaced this bulb, now my light on the instrument panel tells me "Check RR Lamp". I tried to uninstall and reinstall, but the same results. (using the same new bulb) Can someone help me here? Make sure you are using the correct bulb. If the bulb is not the exact number, it can cause this. The resistance is different causing the light to come on. Quote Link to comment Share on other sites More sharing options...
slortiz1 Posted March 5, 2010 Author Share Posted March 5, 2010 I purchased this through Autozone, part# 921LL. The light works, just the light in the instrument panel stays on. Could it be a faulty bulb? Should I take it out and put it back/replace it? Quote Link to comment Share on other sites More sharing options...
akirby Posted March 5, 2010 Share Posted March 5, 2010 You say you replaced the RR back-up bulb? RR lamp usually means the brake or tail lamp, not the back-up bulb. Quote Link to comment Share on other sites More sharing options...
Ron W. Posted March 5, 2010 Share Posted March 5, 2010 Make sure you are using the correct bulb. If the bulb is not the exact number, it can cause this. The resistance is different causing the light to come on. I purchased this through Autozone, part# 921LL. The light works, just the light in the instrument panel stays on. Could it be a faulty bulb? Should I take it out and put it back/replace it? The 906 / 912 / 916 and 921 bulbs are all externally identical and as such interchangeable, difference is candle power 906 = 6cp .. 912 = 12 cp etc. Pull the bulb on the other side and look at the number on it to make sure you have the correct bulb. Quote Link to comment Share on other sites More sharing options...
slortiz1 Posted March 5, 2010 Author Share Posted March 5, 2010 The light was not on before on the instrument panel, until I replaced the burnt out bulb. the is all I replaced (back up) bulb Quote Link to comment Share on other sites More sharing options...
akirby Posted March 5, 2010 Share Posted March 5, 2010 The light was not on before on the instrument panel, until I replaced the burnt out bulb. the is all I replaced (back up) bulb Exactly. You had a burned out back-up bulb which is not monitored so no message appeared. When you replaced the back-up bulb, either your RR brake light or tail light burned out. Replace it. The 2 are not connected except that you were doing work in the same area when you did the back-up bulb. Quote Link to comment Share on other sites More sharing options...
