Razdan Posted May 7, 2013 Share Posted May 7, 2013 I have been reading and debating the shark fin from http://www.visualgarage.com/home.html to replace the standard antenna. My worry is that a touch free high pressure wash is going to take it off the car. Are there any owners who know that the adhesive tape will keep it on the vehicle? Quote Link to comment Share on other sites More sharing options...
Bearcats98 Posted May 7, 2013 Share Posted May 7, 2013 From what I have been reading that if you prep the surface correctly it isn't going anywhere which is why all the concern about lining it up exactly correct the first time through as you are not going to get a second chance to pull and reapply it. Quote Link to comment Share on other sites More sharing options...
47Minutes Posted May 7, 2013 Share Posted May 7, 2013 From the VG website FAQ... Does the VG Shark Fin Antenna hold up to a car wash? Yes, the VG Shark Fin Antenna is secured firmly to the roof of your car with 3M automotive adhesive and will withstand numerous car washes, both soft cloth as well as touch-less car washes. As Bearcats98 mentioned, surface preparation is the most important step. Quote Link to comment Share on other sites More sharing options...
gdn Posted May 8, 2013 Share Posted May 8, 2013 Once you put it on - it isn't going anywhere. Quote Link to comment Share on other sites More sharing options...
Razdan Posted May 8, 2013 Author Share Posted May 8, 2013 Seems the consensus is that it is not going anywhere. I had heard the factory whip antenna could get lost in a car wash and I was hoping this would stand up to it. I guess I will give it a try. Quote Link to comment Share on other sites More sharing options...
rprobst Posted May 9, 2013 Share Posted May 9, 2013 I have the VG shark fin and have had 2 car washes so far. No problems. As has been said, you will not have a 2nd chance to align the fin, the tape on it is REALLY sticky, so line it up carefully. Measure twice, cut once. Except not "cut" but "stick". I placed the fin where I thought it should go, put tape around the fin to outline it, then measured the distances between the tape segments and the antenna base and realized I had not properly centered the fin the first time. So I moved the tape segments and measured again. And then adjusted again to get it really centered. All this before removing the protective cover over the fin's sticky tape. Once you touch the sticky tape on the fin to your roof, you are committed. But you could still get a slight angle as you place down the back of the fin, so keep it carefully centered until it is all touched down. Then, as the instructions say, press firmly for a couple of minutes. Quote Link to comment Share on other sites More sharing options...
http Posted May 9, 2013 Share Posted May 9, 2013 So, on the off chance that you would want to revert back to the whip antenna, can the fin be removed? I'm not too handy and often mess up stuff like this, so I'd like to hear from your experience before I invest $69+s&h. I figure if I mess up the first attempt, I could remove the fin, buy some tape from Loew's or Auto Zone and reapply. Could you carefully cut the tape with a razor blade and then re-prep the surface? Quote Link to comment Share on other sites More sharing options...
rprobst Posted May 10, 2013 Share Posted May 10, 2013 Don't know. The instructions from VG stress that you want to line it up carefully before pressing it on. Quote Link to comment Share on other sites More sharing options...
WhizKid21 Posted June 6, 2013 Share Posted June 6, 2013 Glad to know my fin will survive a carwash. Sometimes it's just easier than pulling out the bucket. lol Quote Link to comment Share on other sites More sharing options...
hodgewdm Posted June 6, 2013 Share Posted June 6, 2013 No problem at the car wash. Ran mine thru the next morning and it didn't move. Love it.. Quote Link to comment Share on other sites More sharing options...
hermans Posted June 6, 2013 Share Posted June 6, 2013 I get mine washed twice a week - no issues. Quote Link to comment Share on other sites More sharing options...
MSPFusion Posted June 6, 2013 Share Posted June 6, 2013 When placing the Shark Fin, I recommend that you make and use a paper template. Someone else on here had suggested it and I did the same. Makes the placement much less stressful. Quote Link to comment Share on other sites More sharing options...
