supremor Posted May 13, 2013 Share Posted May 13, 2013 If sharing is caring, the folks at Ford care about the Fusion Energi. They started caring by sharing the same powertrain that motivates the C-MAX Energi: a 2.0L Atkinson-cycle I-4 that makes 141 hp @ 6000 rpm and 129 lb.-ft. of torque @ 4000 rpm. Matched with a 35 kW, 47 hp permanent magnet AC synchronous motor, system output is 188 hp with a peak of 195 in charge depletion mode. It also shares the eCVT transmission, regenerative braking and front-wheel drive configuration of the C-MAX models. Read more here. Follow us: Twitter: https://twitter.com/carfanatics Facebook: facebook.com/CarFanaticsForum and https://www.facebook.com/CarFanaticsBlog Pinterest: http://pinterest.com/carfanaticsblog/ Quote Link to comment Share on other sites More sharing options...
