Jamers 14 Posted June 14, 2013 (edited) Many of us have tested numerous DE3175 Festoon LEDs for the Puddle Lamps with no success. Any and all LEDs will pulse in the 2013 Fusion. I happen to also own a 2013 Explorer which uses the exact same Puddle Lamps however the LED replacement works just fine in that vehicle. Something is obviously unique about the Fusion's electrical system. Through hours of research and testing I have found the correct resistor to eliminate the pulsing when using a LED in the Puddle Lamp. I also had to spend $40 on a decent Digital Multimeter (DMM) to take measurements. A special thanks to Harley#356 over in the ExplorerForum.com for his expertise. The root cause of the pulsing was due to the fact that the LED light draws significantly less current than the stock bulb. 1/10th watt as compared to 4.8 watts. This would cause a fault in the system. The solution is to install a resistor to draw enough current to illuminate the LED but no too much that the resistor would get dangerously hot. The function of a resistor is to draw current and dissipate it in the form of heat. I found that a 150 ohm 3 watt resistor provided the proper balance. It draws approximately 1 watt of current therefore it never get hotter than 130 degrees. The 3 watt designation on the resistor is just it's rated power capacity. With a 150 ohm 3 watt rated resistor on a 12v system it is only drawing 1 watts of current therefore it is well under it's rated max of 3 watts. Even after leaving the light on for several minutes it never got hotter than 130 degrees. Hot to the touch but won't melt anything. I tested two brands of LED bulbs although I am confident pretty much any LED bulb will work using my recommended resistor: This one from Putco is a 3 LED and fits very nicely into the Puddle Lamp housing. I slightly bent the metal prongs over the edges of the festoon circuit board and it was securely locked into place. Don't be fooled by it's small size; this LED is very bright. Free shipping so $21.50 for a pair. http://www.amazon.com/gp/product/B007RXI4JM/ref=oh_details_o00_s00_i03?ie=UTF8&psc=1 This is the first set of LEDs (in Cool White) I purchased and use in my Explorer. They worked fine in the Explorer as I stated earlier but would only work in the Fusion using the resistor. Although they are 4 LED they are actually slightly less bright than the Putco LED's above. However they are still plenty bright enough. These are a little tighter fit due to the larger circuit board but will still work. With shipping you will being paying $17 for a pair so you might as well get the Putcos above. http://www.superbrightleds.com/moreinfo/festoon/de3175-led-bulb-4-smd-led-festoon/238/ As for the resistor itself, not all resistors are the same. Here is the one I found worked the best. It is small enough to fit between the Puddle Lamp connectors. I have them positioned not to touch anything and there is just enough space in the side mirror housing as well. It's hard to see in the pic but the resistor sits more between the connectors rather than above them. This way I know it's not pressing on anything. Even if it were it the resistor does not get hot enough to melt anything. http://www.ebay.com/itm/140740589823?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649#ht_686wt_945 By the way, the LED Puddle Lamps look awesome on my Fusion. Especially since I have already changed out the from parking lamps and rear license plate bulbs with LED. I also have installed HIDs so I have nice Cool White (5000-6000k) light all over. Edited June 14, 2013 by Jamers 3 c.blackfoot, Applefish and Mehcoib reacted to this Share this post Link to post Share on other sites
BadRock 17 Posted June 14, 2013 Bravo! I just got my car delivered this week and wanted to attack this subject but haven't had the time. I'd love to see a YouTube video of the final result in action. Does the dimming (theater effect) still look fluid? Again, nice work. Share this post Link to post Share on other sites
Jamers 14 Posted June 14, 2013 Sure, I'll shoot a video this evening and post. Theater dimming works perfectly. Share this post Link to post Share on other sites
Jamers 14 Posted June 15, 2013 These pics and video say it all. Standard factory Puddle Lamp on Passenger's side and LED Lamp on Driver's side. The picture showing both sides at once displays just how much brighter and whiter the LED lamp appears. Keep in mind this is reflecting off of my tan garage floor. Had my car been on the driveway it would have appeared even whiter. http://www.youtube.com/watch?v=fRO0YMKOw4c 3 c.blackfoot, BadRock and neod192 reacted to this Share this post Link to post Share on other sites
neod192 114 Posted June 15, 2013 Keep in mind this is reflecting off of my tan garage floor. Had my car been on the driveway it would have appeared even whiter. Your garage floor is very clean and shiny! What did you do to it and how do you keep it so clean? Oh, the lights are cool too :-) 1 hodgewdm reacted to this Share this post Link to post Share on other sites
bobo69 2 Posted June 16, 2013 Anybody try these? http://www.daytimebrightlites.com/Puddle_Lights_NL3C.html Share this post Link to post Share on other sites
hodgewdm 6 Posted June 17, 2013 Anybody try these?http://www.daytimebrightlites.com/Puddle_Lights_NL3C.html I believe that someone has tried those and they flicker. Jamers is the first person I have heard of that has corrected the flickering problem by adding the resistor as he said in his post. Share this post Link to post Share on other sites
Jamers 14 Posted June 17, 2013 I reached out to the daytimebrights guy and he said he had the same pulsing in the Fusion but was too busy to figure out how to solve the problem. 1 hodgewdm reacted to this Share this post Link to post Share on other sites
bobo69 2 Posted June 17, 2013 Well that officially sucks...I was hoping for an easy swap for my mkz when it comes in. Share this post Link to post Share on other sites
jinx8402 65 Posted June 17, 2013 Well that officially sucks...I was hoping for an easy swap for my mkz when it comes in. You could always order from daytimebrightlights, and then add the resistor as pictured here. Share this post Link to post Share on other sites
bobo69 2 Posted June 17, 2013 You could always order from daytimebrightlights, and then add the resistor as pictured here. Well if I gotta add the resistor I might as well just do all the work I suppose. Share this post Link to post Share on other sites
jinx8402 65 Posted June 17, 2013 Well, I was assuming you just didn't want to cut open the puddle lamps, which is much more labor intensive than adding the resistor to the terminals. Share this post Link to post Share on other sites
bobo69 2 Posted June 17, 2013 Well, I was assuming you just didn't want to cut open the puddle lamps, which is much more labor intensive than adding the resistor to the terminals. Now that changes everything! I didnt know you had to cut open the housing... Share this post Link to post Share on other sites
c.blackfoot 0 Posted June 17, 2013 I was the guy that mentioned "DayTimeBrightLights" in another post. I have been in contact with Dan, the owner, and he is going to get some of the resistors mentioned above. He should have them tested by the end of this week. I will let you guys know his findings or you can just email him. Much thanks to Jamers for his hard work/research and sharing it with the rest of us. Share this post Link to post Share on other sites
BadRock 17 Posted June 18, 2013 These pics and video say it all. Standard factory Puddle Lamp on Passenger's side and LED Lamp on Driver's side. The picture showing both sides at once displays just how much brighter and whiter the LED lamp appears. Keep in mind this is reflecting off of my tan garage floor. Had my car been on the driveway it would have appeared even whiter. http://www.youtube.com/watch?v=fRO0YMKOw4c Looks great, what do you have going on in your headlights, they look great too! 1 flyboy19 reacted to this Share this post Link to post Share on other sites
shaggy314 54 Posted June 19, 2013 If I replace me reverse lights with LED 'bulbs' will they pulse too? Share this post Link to post Share on other sites
MineralstangGT 37 Posted June 19, 2013 If I replace me reverse lights with LED 'bulbs' will they pulse too? I believe the puddle lamps are the only issue, but I'll let someone who has done it chime in. Share this post Link to post Share on other sites
BadRock 17 Posted June 19, 2013 If I replace me reverse lights with LED 'bulbs' will they pulse too? I don't think I've seen anyone report this problem but I am looking to do the same and I am curious which lamps you are using. Share this post Link to post Share on other sites
c.blackfoot 0 Posted June 20, 2013 (edited) I replaced my reverse lights with a pair of LEDs that I ordered from iJDMTOY.com and no flickering or pulsing. I also replaced the parking lights and trunk light, no problems. Edited June 20, 2013 by c.blackfoot Share this post Link to post Share on other sites
jared6788 51 Posted June 20, 2013 Reverse Lights don't pulse for myself and many others Share this post Link to post Share on other sites
Jamers 14 Posted June 20, 2013 (edited) I replaced my Reverse Lights with these and they look great and function perfectly. Got them from http://www.amazon.com/gp/product/B007I75D8W/ref=oh_details_o03_s00_i00?ie=UTF8&psc=1 My only complaint might be that up close you can see the yellow color of the LED diode. Edited June 20, 2013 by Jamers Share this post Link to post Share on other sites
shaggy314 54 Posted June 24, 2013 I've tried once to get to mine and I guess I do not want it bad enough, is it just a matter of pulling in the right spots or what? Share this post Link to post Share on other sites
Jamers 14 Posted June 26, 2013 I've tried once to get to mine and I guess I do not want it bad enough, is it just a matter of pulling in the right spots or what? Do you mean to say you couldn't remove the taillight in order to access the bulb? I followed the instructions in this thread. It was really easy. 3 bolts total to remove http://www.blueovalforums.com/forums/index.php?/topic/52427-2013-fusion-reverse-lights/?hl=reverse Share this post Link to post Share on other sites
shaggy314 54 Posted June 26, 2013 (edited) I'm more scared about pulling on the lid covering fabric/liner/cardboard, if they just pop off? I have to unbolt the lights to get at the reverse light bulb? /sigh. I got the reverse lights swapped out, I just didn't want it enough the first time. Edited July 3, 2013 by shaggy314 Share this post Link to post Share on other sites
Jamers 14 Posted June 28, 2013 It really isn't really as hard as it sounds. It's about a 15 mins project. Share this post Link to post Share on other sites
