bighank Posted November 24, 2013 Share Posted November 24, 2013 Loose keyblade on Taurus X remote/key The keyblade (metal) in the plastic remote/transponder key has become loose. It twisted as the steering wheel was torque locked. I to start the car and get home. Opened the cover and used a visegrip to reseat the keyblade to the straight position. The remote/transponder portion was loose at the top end where the blade exits but seems to be glued into the plastic housing. Did not try to pry it out as I didn't want to wreck the key altogether.Can I pry out the remote/transponder packaged in the plastic that is partially unattached in my key? Can I then successfully reattach or make the keyblade solid with epoxy or other means?See aftermarket remote/transponder SHELLS which contain a keyblade but not the remote or transponder chips. If I get one of these how do I successfully transfer the remote/transponder electronics from my existing key? Quote Link to comment Share on other sites More sharing options...
