FORDS ALUMINUM BODY SECRET:
Craig Morton
Our 2015 Ford Expedition with 20,000 miles in California has Aluminum Corrosion on the front hood and rear hatch door. Ford has known about this problem since the year 2000 and has done nothing about it, documented in Technical Service Bulletin TSB 16-0028. Dealerships are aware, but do not disclose the factory defect prior to sale, which is Fraud.
First, the TSB was not released until 2016.
Second, a TSB only recommends the best repair procedure.
Third, no one at a dealership is responsible for reading every TSB and and disseminating the information to sales reps.
That TSB applies to 10's of thousands of vehicle.
Well, unless someone from inside the company comes forth and explains the "root cause" of the problem (likely salt water caused corrosion) we will never know. It is known that very small amounts of cross-contamination (iron dust) on aluminum prior to priming will quickly cause corrosion. It is also know that the best anti-corrosion primer for aluminum is zinc chromate based (typically a yellow-green color) and NOT the standard steel auto primer.
We do know that Ford is using a new aluminum alloy on the F-series (and likely the Expedition/Navigator) that had NOT been used for auto body panels and is has a new Alco patented treatment (pre-primer). that is applied (IIRC) before the metal is shipped to Ford.
In my own personal "quest", I have spoken to several different professional "bump and paint" folks Most will gladly take your money and offer no warranty to sand, fill and paint. Some will recommend replacing the entire panel ($$$) ! One or two go to elaborate lengths of complete removing all trim and components off the door.hatch, removing all paint and primer INCLUDING ON THE INSIDE !! Filling low spots is followed by priming with zinc chromate primer, regular primer, base coat, clear coat and complete re-assembly (also $$$).
Edited by theoldwizard
I thought part of the problem is that some parts like Mustang hoods came from suppliers already painted and/or primed.
I have often wondered about this. Sounds feasible, as hopefully Ford would be aware of the likelihood of cross contamination if the panels were stamped sides-by-side with steel panels. I still believe that improper preparation (Were tha panels proper cleaned after assembly ? Did they use zinc chromate primer ?) is the root cause.
that may have used to have been the case with the Mustang at least, but the current Mustang hoods are entirely handled by FRAP from stamping all the way to the end of final assembly.
I did about 15K worth of front end damage to my Mustang about a year after I got it when I rear ended someone. The hood was replaced and painted by the body shop and I still have bubbling paint under the hood where the creases are.
I don't think this is a factory issue, unless the hood supplier is accidentally contaminating them somehow.
MY2015 onwards for sure the supplier is FRAP
Did the crash parts have zinc chromate primer under the standard primer ?
Proper cleaning of the bare metal, after the part is assembled, and priming are key to preventing aluminum oxidation.
No clue to be honest with you....this was on my 2006
Same thing going on with the Aluminum hood on the Explorers.. paint bubbling and flaking off on the front lip (mostly under the front lip of the hood). Mine has all the bubbles but hasn't flaked off so I haven't done anything about it.
My understanding was that the aluminum parts were being dipped along with the rest of the vehicle on a universal coating and now the aluminum parts are being dipped by themselves with a better treatment (as mentioned above).
Only time will tell but hoping that this has been resolved as this could be disastrous with Ford on the Fseries if this becomes an issue.
I'm hoping you're right as well. I had bubbles on the rear tailgate of my 07 Expedition. I have seen my fair share of bubbles and peeling on those aluminum parts on other Fords as well. As a matter of fact, I followed an Expedition to work this morning that had a really bad looking tailgate. I would like to think they have this figured out now, considering the major implications it has for the company.
  • 7 months later...
I just booked my 2016 in to get the hood and tailgate repainted, have had it exactly 2 years and noticed it in the summer and getting much worse now. All 4 of my Expeditions have had this happen and whenever I see a used one drive by I take a look and sure enough today I saw a white one with paint peeling around the tailgate handles and the chrome trim piece. Not sure how some of you can say it's not a big problem. I have just accepted it's part of owning one but I hope they have solved this for 2018 because the whole damn thing is aluminum.
I hope you are right about the 2018, as Ive seen a lot of older ones with this problem. If the F150 is indicative, Im optimistic this is resolved.
It seems to only affect specific vehicles, so it must be a factory problem as opposed to a general Ford problem. I know Lincoln LS owners with aluminum hoods and fenders that have never had a problem in 17+ years.
I really think this is the "root cause" ! Quality control at supplier that allowed some type of contamination on the surface prior to them painting it.
I will never be able to find it now, but when the aluminum F150 came out there were several news articles how Ford had worked with Alcoa to develop a special coating that was applied at the aluminum factory. I think the term the industry uses is "pickling". This not a primer, which is applied after the body panel is formed, but I am sure that Ford is using the best aluminum primer available,
  • 2 weeks later...
A trusted Ford expert told me a few months ago that they finally figured out the problem. According to him, they stamped steel panels on the same dies as the aluminum panels, leaving just a molecular trace of ferrous material as a residual on the dies. When the aluminum panels are then stamped, the residue transfers to the aluminum. The dissimilar metals then corrode. I know, sounds far fetched, but they have since quit using the dies for steel parts and the problem is supposed to be solved.
By the way, my 2005 Expedition had some small corrosion starting to show about two years ago. It was never garaged, ran Ohio roads in the winter, and only had a few small corrosion spots when I traded it in on the new Super Duty two months ago...however, the Rocker panels (steel) were completely rusted off all the way into and past the door seals. Compared to the rocker panels those aluminum parts held up pretty good I'd say!
Harry
Not sure what you call it bump/dent guard/shield, but the gen3 Expeditions had a 9 inch vinyl trim layer around the bottom body that would appear to protect the body from dents.
I don't see this in the new Gen 4, is the lower aluminum body exposed to dents especially from opening the door against a gas pump cement post for example? Or is it there and just not apparent from the photos.
Dennis
  • 1 year later...
