fordtech1
Gm Diesel engines not compatible with US Fuel
And.... this is why don't buy a work truck from Government Motors  🙄
Say what you want about Ford cars.... but there's a reason their trucks are number 1.
Edited by probowler
Ford has had their fair share of this EXACT problem from 2011+ trucks.  It is all over the internet.. Ford charging $10k for a full fuel system replacement.  All because it showed a few specs of rust from a fuel that naturally has water in it.
Ford's water separator on these is pure junk.  It's the reason I spent $700 I shouldnt have had to for a dual filter fuel filter system added on to actually do its damn job and absorb the water/moisture.  All of this happening without the WIF light ever coming on.
I have Blue blood but your comment is ridiculous in this regard as Ford and GM are no different here.
No kidding? I guess I shouldn't speak on topics i'm ignorant of 🤐
Well I'll go just Fk myself LOL. I do appreciate you educating me though.
Ford uses Bosch pumps, just like GM. BUT this is an issue with ALL common rail diesel even the almighty Cummins. Tiny little pump making 25k psi? Even a small bit of contaminant is an issue. This isn't a Bosch 'design flaw' or  'Ford separator problem', it is that common rail is in itself fragile. But the need to make less tailpipe and noise emissions from compression ignition has forced manufacturers to it.
Don't buy crappy fuel from shady stations. Don't skip draining the separator. NEVER use emulsifiers. DO use lubricators. Don't treat a fragile diesel like a comparable gas vehicle that *can* take abuse.
DO build a pump that can handle 25k psi if that is what you are requiring, DO build a pump that does not destroy itself, DO build a fuel system that does NOT send the metal particles through the whole fuel system (aftermarket has already come up with solution so it does not), DO build a fuel system that can handle American diesel, DO build a water separator that actually separates water (aftermarket has done this prior to 2017MY), DO honor a warranty on the junk pumps instead of sticking customers with a $10k bill because Ford doesnt want to design a proper filtering system.  DO state that additives are REQUIRED in order to prevent a grenade if they are indeed required.
I've spent years reading owner after owner getting stuck with a $10k bill when they havent done anything wrong (yes, there are some that have no clue what a water separator is).
Commonrail is fragile. A plain and simple truth that cannot be simply engineered out. Water and/or fluids that don't lubricate the pump will kill it. One bad tank of fuel will end ANY commonrail pump's life, no matter what whiz-bang aftermarket "fix" they have for the systems or whose name is stamped on the housing (Bosch, Cummins, Continental, etc). In "the good old days" of distributor pumps and HEUI systems, bad fuel/loss of fuel pressure would damage them too. It is the nature of the beast with any diesel. The old adage, now a myth, of a diesel being more reliable and longer lasting than its gas powered counterparts needs to die.
Why should Ford/GM/Ram eat a bill for someone who put gas in their tank? Or DEF? Or water? Or ran it out of fuel or low on fuel pressure so the pump couldn't lube itself? Or didn't drain the separator ever, or never changed filters, or... the list goes on. I bet if you really dug into those internet sob stories, the majority are leaving out details. People who care for their vehicles, like yourself, rarely have troubles.
Reason is that Ford brought back Ranger for 2019 in the U.S. market. That added 30,000+ trucks to Ford sales for the 1st half of 2019. And pushed Ford past GM, which has traditionally been the #1 seller of pickup trucks in the U.S.
