news coming....
24 minutes ago, silvrsvt said:
That's because they have transmissions and tuning that can affect them.
BEVs for the most part are direct drive and don't act like ICE-1 RPM gives you full torque output on a electric motor vs a gas engine
It could work though. The switch could just tell the computer how to utilize the battery for max power or efficiency or whatever.
I'm probably explaining it really bad but I have the idea thought through in my head
I'm not sure how much of an improvement you'd really get-its just like people bitching about "insane" power levels that ICE engines have-alot of that is due to improved efficiency of the engine and transmission.
You'd really just be changing the acceleration response and maybe the regenerative braking.  Now if you had multiple motors you could change a lot.
From the way I understand it- you can technically drive a BEV with one foot-no power applied the motors means they would brake the car like brake pads would. Not sure how much regeneration you get that way.
https://jalopnik.com/the-truth-about-brake-pad-replacement-in-teslas-and-oth-1831591519
Edited by silvrsvt
That's just regenerative braking.  If you let the motor turn on its own due to the vehicles kinetic energy it generates electricity and stores it back in the battery (the opposite of what happens when you press the accelerator).  However, I assume there is some freewheeling if you take your foot off the gas but don't touch the brake pedal.  That would seem counterproductive not to freewheel and coast.  But when you touch the brakes it will be mostly regenerative up until the point it needs assist from the brake pads like a panic stop.
It's really no different than engine braking in an ICE except you're recovering the lost energy.
4 hours ago, Deanh said:
doesn't Porsches new BEV have a two speed trans?...
Yes, but even with an amazingly low Cd, it’s range still isn’t that great (260-270mi EPA)...it can’t touch a standard single-speed Model S (370mi EPA).  The next S should be in the 400+ range.
...I essentially drive one foot in mine.  It becomes very natural after a day or two behind the wheel.  Really maxes out the regen.
 I know in the Teslas (at least the Model X I drove), you can change it between a sort of "traditional" setting where it'll act like a normal car and coast to a stop, or you can have it in a sort of "heavy" regen mode where you don't even need to use the brakes, it'll bring you to a stop fairly quickly.
2 hours ago, Deanh said:
feel for you, especially when things are exciting...embargos suck for us curious ones...but necessary so as "bombshells" actually achieve the impact Fords wants...due to leaks, so many have fizzled by release dates....let alone competitors get insight before release.
All of the Detroit Three manufacturers test vehicles in northern Michigan.  I've lost count of the number of camo'd vehicles I've seen.  Several years back when GM brought out the then-new Impala, an entire fleet of test vehicles (and competitors) drove down the road right in front of our house (which is in the country).  I keep hoping that Ford will bring a fleet of Broncos up to northern Michigan on a test run.  Alas, so far, nothing.
If I remember correctly, the two speed trans in the Porsche is to get a higher top speed.
If that’s the case, it didn’t do much.  Tesla is 162-163, I think Porsche claims the same for theirs, though someone claimed to hit 167 on the autobahn, but I don’t know if that was real or down-hill wind at the back and speedo error.
Tesla claims 250+ for the Roadster.  I don’t know how they’re planning on hitting that.  It would have to have a transmission.
So the throttle is all-go or no-go? That's what you're suggesting. 100% torque all the time. That just isn't true. The throttle can be programmed with limits  such as max 50% torque output in Eco mode.
DC electric subway trains have have adjustable throttles since 19th century. It can be done.
Yes, if your not applying the accelerator-your getting regenerative braking from the motor slowing the car down.
Graph showing Typical DC Motor / DC Gearmotor Performance Characteristics (The 108-104 DC Motor)
Going by the graph above, applying less power will make the motor less efficient.
100% or nothing. Got it.
But given the level of tech available in the auto industry alone, not including tech available elsewhere, i dont believe for one minute it cant be done.
Tesla makes an awful lot of claims...so the award for the biggest grain of salt gos to......
Cordless tools have variable speeds.  It’s not that difficult.
That isn't the point-Operating a electric motor at a lower speed isn't the same as operating an ICE at a lower speed (aka RPMs) because the ICE is using a fuel to power it.
A DC Motor uses the same amount of power (current) when it operates, no matter the speed...at least thats how I understand it.
Isn't it amperage that regulates the speed?
But don’t they use A/C traction motors to make drive and regen a lot more efficient?
Depends on application-
https://cleantechnica.com/2018/03/11/tesla-model-3-motor-in-depth/
https://www.tesla.com/blog/induction-versus-dc-brushless-motors
Battery power is DC
AC power is normally generated by a generator
Battery power is DC
Until the Tesla 3, Tesla used A/C traction motors,
they went DC permanent magnet for the 3 to lower costs
I’m hoping that Ford is on their game with Mach E and turns Tesla on its head
Edited by jpd80
... well, I drive a 300mi range AWD performance sedan that goes from 0-60 in 3.2s that only cost $56k.  As far as I know, Tesla is the only one currently making anything remotely close to that.  Porsche will, for only $100k more...next year...except for the range.  Tesla deserves a little respect in that regard.
...1-switched reluctance, partial permanent magnet motor and 1-AC, actually, on the 3P.
