Bronco and Bronco Sport World Premier July 13th!!
2 hours ago, rperez817 said:
Thank you for sharing a dealership perspective ice-capades sir. Dealer relations is one area where Ford has a lot of room for improvement.
In last summer's NADA Dealer Attitude Survey, these were the brands that scored highest.
1. Lexus
2. Toyota
3. Honda
4. Subaru
5. Porsche
6. Mercedes-Benz
7. Kia
8. Volvo
9. Hyundai
10. BMW
In this survey, franchised dealers rate their relationships with their automaker partners in areas like ability to make money, listening to dealers, and honoring promises made. https://www.autonews.com/dealers/dealers-still-lexus-toyota-most-survey-finds
Ford is also stuck with many dealerships with s*** locations with the franchisee won't/can't move, refuse to update their showroom; do the bare minimum to keep open and won't close/want a ridiculous amount to be purchased. You walk into a Ford showroom stuck in the late 70' and walk into a Hyundai dealership built in the last 5 years its not rocket science as to where you feel more comfortable buying a car.
1 hour ago, bzcat said:
That's a straw man argument. Ford wouldn't be opening a new factory to just build 100k Escape. They'd be adding 100k Escape to a plant that is making 200k other vehicles. And we know Ford had plenty of spare capacity because it turned out Cuatitian, Flat Rock, Hermosillo, Michigan, and Oakville were all capable of producing more vehicles without a lot of new overhead. It's one of the reason why the 3rd Mexican plant was cancelled.
And if you look at what actually happened, the compact CUV segment grew a lot over the last 5 years or so. This is one of those times where you need to have the capacity... more Escape would have sold without huge amount of incentives. People were trading in cars for CUVs and Ford didn't have enough CUVs to sell. The next best thing to do was to raise prices... but in order to do that, you need to have fresh product, which Ford... didn't have. So basically, Ford had the worst of both worlds... not enough volume to compete in a growing market and can't sustain higher prices given the volume constrain.
I do agree with you that the new plan for Hermosillo makes sense - building Bronco Sport and Transit Connect there with potential for Escape overflow is smart planning. Something unfortunately Ford didn't do very well during the last cycle. But Cuatitlan and Oakville still have a lot of capacity there not being used.
Oh I agree they screwed up long term planning by not having flexible capacity.  FRAP can’t build utilities and Hermosillo was at max capacity.
I’m just saying that at a given point in time it may not be financially viable to expand production and limiting it to one plant with higher ATPs might make sense short term.
It’s a balancing act - less capacity means less overhead and easier to withstand a downturn.  But it also makes it harder or impossible to take advantage of market opportunities.  I think we agree Ford is too conservative and needs more flexibility.
2 minutes ago, akirby said:
But you still have Bronco Sport and whatever special versions either way.  What you’re proposing is they throw away Escapes 15k units per month (with good profit margins) just because you don’t like the styling.  I don’t understand the logic.    I mean I can’t stand Camry styling but they sell almost 400k/Yr.  Everybody’s tastes are different.
What I’m saying is I believe ford would make more money by doing a one vehicle strategy.
i don’t think the bronco sport will outsell the escape now because the escape has a lower price and will have more rebates, however, if the bronco sport was offered in 2WD and cost the same as the escape, i am positive it would outsell it by a good margin. I think the money ford spent on making two vehicles could have been spent on making one vehicle better. Ford should have adopted the model they have been using on the f150 (which Toyota now started doing with its rav4), which is giving each trim a different front end, lights, interior materials, etc. this would have allowed them to differentiate the vehicle to cover several demographics while saving a ton of money by not having 2 separate vehicles. They could then use those savings to put better materials inside their vehicles, which would in turn make people think it’s a quality product, which then allows ford to charge more because they have added value. This is opposed to their current strategy which is charge more but make everything cheaper. That’s being short sighted and will hurt them in the long run.
I think the jury is out on that. I think you will see that other car companies will be adding similar size but more rugged (or less rugged) compact CUVs as they go about their replacement cycles. Cars leave the line up and CUV replace them, on top of existing CUVs.
You mentioned Toyota RAV4 which is beating Escape right now but Toyota is also planning to add a new model next year. It's rumored to bring back the Matrix nameplate on a CUV that is roughly the same size as RAV4, maybe a little smaller. And there will be a new Venza as well to complement the new Highlander. So everyone is doing the multiple CUV entry thing because the market is growing.
40 minutes ago, probowler said:
Wasn't there a slide somewhere that said ford planned to eventually have like 10-20 hybrid and electric vehicles?  They almost have to put it in the Bronco to make those numbers.
I don't remember the exact number but yeah it was something like that. I thought the plan was pretty much everything gets a hybrid version except for things like Super Duty, Heavy Trucks and HD Transit.
I think the exact wording was hybrids for everything except commercial vehicles which would include what you listed.
Ford counts trim levels of the same vehicle as as different electric and hybrid vehicles,
they've pulled this trick before....
They also include 48V systems hybrids. Which while technically a hybrid don't have huge real world efficiency gains, and are more about CO2 reduction.
44 minutes ago, jasonj80 said:
Everything that was going to launch through the end of 2021 is delayed 60-120 days. Programs under development are also undergoing extensive review, and may lead to more cancellations and reshuffling of plant resources.
My guesstimates:
Mustang Mach E-least affected because pre-production units where being built already?
Bronco Sport-60 days
F-150-60 days or less due to importance
Bronco-90-120 days worse case-Maybe only 60
Rivian based Lincoln (that was supposed to come out the end of next year?) 120 days
Under review:
Small Pickup
Fusion Sportback
I'm surprised they haven't pulled the plug (temporarily) on the Michigan Central Station reconstruction project.  The Dearborn Campus re-do too.
That is being paid for by grants, TIF captures, and is through Ford land however there is a slow down at MCS based on the shut down of construction in the state. Dearborn campus redo is just necessary, to say they were in horrid shape would be kind but also work has stopped as they are not legally allowed to work.
Edited by jasonj80
3 hours ago, silvrsvt said:
My guesstimates:
Under review:
Small Pickup
Fusion Sportback
As for the Rivian-based Lincoln product, Rivian has pushed back production of their pickup and SUV from late in 2020 to sometime in 2021.  I imagine this will push back the Lincoln BEV too.
