Apexmaster33 Posted December 31, 2019 Share Posted December 31, 2019 hi guys, ok, so here is some info on the car. 2002 4.0 V6 180K. recent full tune up, new plugs, wires, alternator, thermostat, air filter, fuel filter. No CEL, fuel pressure 60 psi The engine starts as it should, after 20 sec it just stalls, and dies. it dont matter if I hold down the gas. i cannot solve this one? any idea? Quote Link to comment Share on other sites More sharing options...
YT90SC Posted December 31, 2019 Share Posted December 31, 2019 Does it do it with the MAF unhooked? Quote Link to comment Share on other sites More sharing options...
Apexmaster33 Posted January 1, 2020 Author Share Posted January 1, 2020 i have not tried. i found another post, about common issue with the alternator cable. it runs under water pump, and from heat the cable degreates, and shorts. i wiggle it and car ran for over 1 hour. but i dont think this is the issue.. wouldnt i get a code for MAF? Quote Link to comment Share on other sites More sharing options...
YT90SC Posted January 2, 2020 Share Posted January 2, 2020 No. One way to check for a vacuum leak or an in-spec MAF issue (bug stuck inside, dirty, etc) is to unhook it and see if the issue goes away. Quote Link to comment Share on other sites More sharing options...
