inoaguy Posted January 27, 2020 Share Posted January 27, 2020 Hello....new to this Forum.....tried searching with no luck. Had my 2019 Escape at the dealer to handle the 19b37 FSA done, and also an oil change. When I got home, checked the dip stick and it was overfilled, about 1/2 inch above the MAX mark. This is the 2nd time in my experience with 1.5l engines where its been overfilled. Some online info says 5 qts but my manual says 4.3 qts. Why would the Ford dealer not know to use 4.3 qts? I drained the excess out myself. Any input would be aprreciated...Thanks Quote Link to comment Share on other sites More sharing options...
akirby Posted January 27, 2020 Share Posted January 27, 2020 3 hours ago, inoaguy said: Hello....new to this Forum.....tried searching with no luck. Had my 2019 Escape at the dealer to handle the 19b37 FSA done, and also an oil change. When I got home, checked the dip stick and it was overfilled, about 1/2 inch above the MAX mark. This is the 2nd time in my experience with 1.5l engines where its been overfilled. Some online info says 5 qts but my manual says 4.3 qts. Why would the Ford dealer not know to use 4.3 qts? I drained the excess out myself. Any input would be aprreciated...Thanks It may have changed mid production or it was a typo and the dealer info still says 5 qts - and they're too lazy to check it. Just make sure to tell them next time - maybe put a sticky note on the oil filler cap! Quote Link to comment Share on other sites More sharing options...
inoaguy Posted January 28, 2020 Author Share Posted January 28, 2020 Thanks...So I'm going to assume the real capacity is 4.3 qts.....Clever idea about the sticky note! Quote Link to comment Share on other sites More sharing options...
