bradleyheathhays
Feelin' a little shaky
I've got an '02 Ford Taurus with 99k miles that's got something loose in the front end but I'm not entirely sure what it is. When under moderate to hard braking there's a quick shaking in the front of the car and the steering wheel jerks in sync with the shaking. Jacked up one front wheel, left the other on the ground, and sure enough the wheel moves when pushed at 3 and 9 o'clock, but not at 12 and 6.
Any advice on where to go from here?
If it only happens when braking, the rotors are warped. Have the rotors resurfaced or replaced depending if they are thick enough.
thanks, just had the same problem
just replace the rotor and be done.
When coming to a hard stop, if at all possible, roll the car forward a bit and put it in neutral.  That heat soaking of leaving brakes pressed warps the poor quality material they put into today's vehicles.
