vipersinu2 Posted April 8, 2020 Share Posted April 8, 2020 (edited) Question, does your aluminum a/c line get cold? After the cam phasers replacment it seems the A/C is cool not cold. I had on max A/C and my wife was comfortable! Edited April 8, 2020 by vipersinu2 Photo Quote Link to comment Share on other sites More sharing options...
Black Label Posted April 8, 2020 Share Posted April 8, 2020 Getting up in the upper 70s here later, I'll try to check. I don't have a tool like that to do an accurate check, but I can say yesterday driving around before you posted this, my a/c seemed to be cold. In fact, I bumped it up a couple degrees in "AUTO" mode. Are you thinking they screwed something up during the cam phaser replacement? Also, did you mean to say you had it on max but your wife was uncomfortable? Quote Link to comment Share on other sites More sharing options...
vipersinu2 Posted April 8, 2020 Author Share Posted April 8, 2020 I called the dealer, The service manager is going to ask the technician if he had to evacuate the A/C system. Either way, The manager said bring in the truck to look at the rattle and A/C issue. My wife is always cold and making her side warmer. With max A/C on she should of been freezing! So when she said she was comfortable I thought something was wrong. Lol 1 Quote Link to comment Share on other sites More sharing options...
Black Label Posted April 8, 2020 Share Posted April 8, 2020 29 minutes ago, vipersinu2 said: I called the dealer, The service manager is going to ask the technician if he had to evacuate the A/C system. Either way, The manager said bring in the truck to look at the rattle and A/C issue. My wife is always cold and making her side warmer. With max A/C on she should of been freezing! So when she said she was comfortable I thought something was wrong. Lol Okay, gotcha on the wife thing, that makes sense now. Glad the dealer is going to get it figgered out for ya. ? I'll be curious to know what you find out. Quote Link to comment Share on other sites More sharing options...
YT90SC Posted April 8, 2020 Share Posted April 8, 2020 The green test port is the high side. It should never be cold. 1 Quote Link to comment Share on other sites More sharing options...
GordonZoo Posted April 8, 2020 Share Posted April 8, 2020 Those point and shoot thermometers are only for a larger area. Our Fluke model can only focus in on about a five inch area. The laser is to center your measurement but the collection area is much wider. You are most likely reading the temperatures behind the refrigerant line and it is averaging. If you want accuracy you should use an RTD or at lease a thermocouple wire. Wrap it on the low side refrigerant line with tape to you don't get the ambient air. Quote Link to comment Share on other sites More sharing options...
vipersinu2 Posted April 8, 2020 Author Share Posted April 8, 2020 I will check what an RTD meter is. On my mountaineer the low side is really cool to the touch. The Navigator's low side is cool to the touch, as the mountanieer is very cold to the touch. I attached photo of the mountaineer low side readings. Quote Link to comment Share on other sites More sharing options...
vipersinu2 Posted April 10, 2020 Author Share Posted April 10, 2020 In the shade at 6pm, it is 80° outside. The truck has been running 20 mins. I would say its safe to say blowing cool air between 49° to to 50° out of vents. Do that seem correct? I put both thermometers in ice water and calibrated to 32° the electronic meter was showing 34° in the ice water. I took a picture of all three thermometers and the radio showing the outside temperature. Quote Link to comment Share on other sites More sharing options...
vipersinu2 Posted April 19, 2020 Author Share Posted April 19, 2020 We have not driven the truck in 2 weeks b/c of Coronavirus. A/C not doing to well. I found a TSB for the A/C TSB #19B01 https://m.carcomplaints.com/Lincoln/Navigator/2019/tsbs/tsb-19b01.shtml Quote Link to comment Share on other sites More sharing options...
vipersinu2 Posted May 5, 2020 Author Share Posted May 5, 2020 B/C the truck is at the shop getting a new turbo. They also fixed the A/C. The tech said the freon was low. Quote Link to comment Share on other sites More sharing options...
LHB Posted May 5, 2020 Share Posted May 5, 2020 Sooooo ; next question should be - where did the refrigerant go? Quote Link to comment Share on other sites More sharing options...
vipersinu2 Posted May 5, 2020 Author Share Posted May 5, 2020 The tech could not remember when he opened the front cover to install the cam phasers if he evuaced the a/c system or not. For good measure he put his gauges on and found low freon and then leak tested the system somehow and found no leaks. I think I heard him say he vacuumed it down. He stated the A/C is good now. Quote Link to comment Share on other sites More sharing options...
Black Label Posted May 10, 2020 Share Posted May 10, 2020 On 5/5/2020 at 10:55 AM, vipersinu2 said: The tech could not remember when he opened the front cover to install the cam phasers if he evuaced the a/c system or not. For good measure he put his gauges on and found low freon and then leak tested the system somehow and found no leaks. I think I heard him say he vacuumed it down. He stated the A/C is good now. Wow. Couldn't remember? I mean, isn't that something that the procedure would tell him to do? Crazy. Quote Link to comment Share on other sites More sharing options...
vipersinu2 Posted May 10, 2020 Author Share Posted May 10, 2020 (edited) Hopefully it fixed, We really haven't had a hot day yet to test out the system. Those a/c pipes under the hood aren't super hot or cold. There cool and warm. I dont know of thats something to do with this new type of freon or not. It was 73° outside and blowing 44° inside. Got to 65 inside. But it was a cool day. Edited May 10, 2020 by vipersinu2 Quote Link to comment Share on other sites More sharing options...
