Wheel Offset and Fitment
3 hours ago, Chris Balendy said:
I have a 2002 F-250 and am looking to upgrade my 16x7 wheels to 20x9 with 35 inch tires. What should my wheel offset and bolt pattern be? I want to make sure they will fit.
Hi Chris. Th answer to that question generally depends on what you are trying to accomplish. I would recommend using this "Wheel Offset Calculator" to plug in the wheel sizes you may want and find out what offset or approximate offsets will work.
Wheel Offset Calculator: https://www.1010tires.com/Tools/Wheel-Offset-Calculator
The stock offset for my truck is +6mm, and the wheels I am looking at is +1mm offset. Some guys were saying I can go is low as -2mm offset. So the ones I'm looking at should fit right? Thanks in advance.
Hi Chris. Plug the information into the Wheel Offset Calculator I linked to. It will calculate and display the clearance differences between your stock and aftermarket wheels on the suspension side (inside) and the fender side (outside).
Good luck.
