seandiesel Posted August 15, 2020 Share Posted August 15, 2020 just wanted to know if i have an E350 with no options, is the wiring harness the same? can i install a steering wheel with cruise control and link some wires? can i do the same if i get doors with power windows? or if it’s impossible? Quote Link to comment Share on other sites More sharing options...
twintornados Posted August 16, 2020 Share Posted August 16, 2020 11 hours ago, seandiesel said: just wanted to know if i have an E350 with no options, is the wiring harness the same? can i install a steering wheel with cruise control and link some wires? can i do the same if i get doors with power windows? or if it’s impossible? What year? I was able to add CC to my 2005 F150 XL by getting the switches and related switch harness out of a salvage yard, pulling the blanks out of my steering wheel and installing the switches and harness (plugged into the clockspring without issue) and a trip to the local Ford garage to have speed control turned on in the computer. I have a buddy that wants to put CC in his 2014 E350, research shows that you need to change the steering wheel and clockspring then a trip to the Ford garage for access to the computer. We haven't tackled his yet. As for power windows, I added power windows to my F150 by getting one of those 50 dollar kits you see on Amazon, but in my case, my window regulators were shot so I needed to replace them too. Turns out, manual crank window regulators for my truck were 3X the cost of power window regulators WITH the motor attached so I used the harness, switches and related hardware trim from the kit and spliced the wiring into the power window regulators and VIOLA...power windows! The aftermarket kit included plugs for the hole in the door panel where the window crank was. Quote Link to comment Share on other sites More sharing options...
seandiesel Posted August 16, 2020 Author Share Posted August 16, 2020 it’s a 2012 Quote Link to comment Share on other sites More sharing options...
twintornados Posted August 16, 2020 Share Posted August 16, 2020 7 minutes ago, seandiesel said: it’s a 2012 Cannot find anything for later models past 2008, but this fall, we are going to tackle my buddies 2014....here is a video describing the process in 2005-2008 models. Cannot imagine later years would be much different. Quote Link to comment Share on other sites More sharing options...
