None
waynezo
2008 Milan Defrost Vent Popped out
The dash appears warped from heat.  One tab is broken on drivers side.  the next set of tabs are intact but won't click.  I am afraid just getting a new vent grill wont solve the problem.  Has anyone else had this problem?  Any advice is appreciated
I would try to install a new cover and see what happened, being careful to not break it, of course. If you are concerned about the warpage, you can use the adhesive found in TSB 16-0026 for the airbag opening warp issue, although I am not sure how you would clamp it down without dash removal.
Thanks for the response.  The vinyl is pulled away especially in the middle.  Do you think the tabs on a new part will catch, click, and hold the vinyl down?  Otherwise I will need to glue it first.  I could try to use binder clips or tiny C-clamps.  Where can I find
the glue you speak of?
