akirby Posted September 19, 2020 Share Posted September 19, 2020 I thought it was a new skateboard platform. The suspension might end up the same but I doubt they’re starting with a F150 frame. 1 Quote Link to comment Share on other sites More sharing options...
silvrsvt Posted September 20, 2020 Author Share Posted September 20, 2020 5 hours ago, akirby said: The suspension might end up the same but I doubt they’re starting with a F150 frame. How about taking it a bit further- How about a "skateboard" truck frame that can be shared between the Ranger, Bronco and Expedition? Going on how the Bronco IP/Dash is shared with the F-150, I'm assuming that harnesses and whatnot are also shared between it and the F-150 and the upcoming Ranger...that would go a long way to saving Ford money and development time and maybe a nightmare if there is a recall.... 1 Quote Link to comment Share on other sites More sharing options...
rmc523 Posted September 20, 2020 Share Posted September 20, 2020 17 hours ago, silvrsvt said: How about taking it a bit further- How about a "skateboard" truck frame that can be shared between the Ranger, Bronco and Expedition? Going on how the Bronco IP/Dash is shared with the F-150, I'm assuming that harnesses and whatnot are also shared between it and the F-150 and the upcoming Ranger...that would go a long way to saving Ford money and development time and maybe a nightmare if there is a recall.... How is the Bronco IP/dash shared with the F-150? 1 Quote Link to comment Share on other sites More sharing options...
fuzzymoomoo Posted September 20, 2020 Share Posted September 20, 2020 (edited) 25 minutes ago, rmc523 said: How is the Bronco IP/dash shared with the F-150? Maybe the internal structural bits somehow? Edited September 20, 2020 by fuzzymoomoo Quote Link to comment Share on other sites More sharing options...
jpd80 Posted September 20, 2020 Share Posted September 20, 2020 A variation from the same supplier? Quote Link to comment Share on other sites More sharing options...
rmc523 Posted September 20, 2020 Share Posted September 20, 2020 I mean, it's using the same screen, so it'd use the same mounting points for that. Quote Link to comment Share on other sites More sharing options...
silvrsvt Posted September 21, 2020 Author Share Posted September 21, 2020 18 hours ago, rmc523 said: How is the Bronco IP/dash shared with the F-150? 17 hours ago, fuzzymoomoo said: Maybe the internal structural bits somehow? Center consoles are almost identical to one another button/screen wise Just like the US Ranger uses the switch gear from a Fusion I'm also assuming the subsystems are the same-the both support OTA updates The IPs look different, but I'm assuming they use the same tech Quote Link to comment Share on other sites More sharing options...
rmc523 Posted September 22, 2020 Share Posted September 22, 2020 12 hours ago, silvrsvt said: Center consoles are almost identical to one another button/screen wise Just like the US Ranger uses the switch gear from a Fusion I'm also assuming the subsystems are the same-the both support OTA updates The IPs look different, but I'm assuming they use the same tech I mean, you could say that of much of the lineup that shares switchgear and screens. Quote Link to comment Share on other sites More sharing options...
silvrsvt Posted September 22, 2020 Author Share Posted September 22, 2020 12 hours ago, rmc523 said: I mean, you could say that of much of the lineup that shares switchgear and screens. Right, which means Ford saves money also. Quote Link to comment Share on other sites More sharing options...
rmc523 Posted September 22, 2020 Share Posted September 22, 2020 6 hours ago, silvrsvt said: Right, which means Ford saves money also. I know, of course. I just wouldn't have worded it as "sharing dashes/IP", as they're clearly different even if they share components. At the end of the day it doesn't matter lol. Quote Link to comment Share on other sites More sharing options...
