Black Label Posted February 5, 2021 Share Posted February 5, 2021 I'm curious if anyone knows if the GCM is what allows information to display in the Instrument Cluster in a 2020 Navigator. Specifically, my SiriusXM song info does not appear there, as it should. There is no setting to make this happen. The song title appears on every other audio source I may use, including Pandora, for example. I have had the vehicle in 3 times for this. Frankly, I just don't think they understand the issue, no matter how many times I show them. They have replaced the APIM. No dice. They discovered a bad cell in my battery and replaced it. Did not fix the issue. The dealer has supposedly reached out to the Ford Tech Hotline, I think is what the service manager said. When I brought the vehicle in a couple weeks ago, I mentioned the GCM. Never heard anything about it after that. Could a bad GCM be causing this issue of the SiriusXM only sing title not appearing in my Instrument Cluster? Quote Link to comment Share on other sites More sharing options...
