STDevil Posted February 20, 2021 Share Posted February 20, 2021 Hi all - for those who put new shocks on their trucks, did you re-use your shock bolts? I have a F350 4WD en route and plan to replace the shocks with Bilstiens. The service manual says to discard all of the bolts and nuts. I am guess they are torque to yield but don’t know this for a fact. The parts guy said it’d be about $50 for new hardware and also said that most DIYers don’t replace the hardware. He suggested that I go to Tacoma Screw (if it is a fastener, they probably have it) and get the fasteners there. I am interested in any input from you guys... thanks... Quote Link to comment Share on other sites More sharing options...
pig9r Posted February 20, 2021 Share Posted February 20, 2021 I think you would be fine but peace of mind is worth something too. I have typically reused shock bolts on other vehicles without issue. They say the same about the bed bolts but they get reused all the time. I get most of my hardware online from Bolt Depot. They ship very quick. Quote Link to comment Share on other sites More sharing options...
ScottK1 Posted February 21, 2021 Share Posted February 21, 2021 Unless the bolts were over-torqued, they're fine. If Ford installed them, they should be good. They're just trying to limit liability. Quote Link to comment Share on other sites More sharing options...
twintornados Posted February 21, 2021 Share Posted February 21, 2021 Over the years I have replaced shocks and sometimes they came with replacement hardware so I would use the new bolts, but when they did not come with hardware, I would look at the old hardware and if they were in good shape, I would clean and reuse them. Quote Link to comment Share on other sites More sharing options...
fuzzymoomoo Posted February 21, 2021 Share Posted February 21, 2021 If the bolts look like they’re still in good shape and not cracked and the nylon in the nuts still looks good you can probably reuse them. If you want to replace them just to be on the safe side, make sure the replacements are grade 8. Quote Link to comment Share on other sites More sharing options...
akirby Posted February 21, 2021 Share Posted February 21, 2021 I’ve never seen torque to yield bolts on shocks. Quote Link to comment Share on other sites More sharing options...
STDevil Posted February 22, 2021 Author Share Posted February 22, 2021 Well I ended up ordering new fasteners. Everything comes in packages of four, so I have twice as much as I will need. If anyone in the Seattle area is interested in buying the left overs, let mw know...otherwise, they'll go in my nut and bolt organizer... Quote Link to comment Share on other sites More sharing options...
