jcartwright99 Posted May 5, 2021 Share Posted May 5, 2021 C&D Quote Link to comment Share on other sites More sharing options...
silvrsvt Posted May 5, 2021 Share Posted May 5, 2021 I like that green...looks pretty good for an appearance package with suspension tuning. Quote Link to comment Share on other sites More sharing options...
T-dubz Posted May 5, 2021 Share Posted May 5, 2021 This would be perfect with about a little more ground clearance and the ST grille. With the lights in the grille, I think lots of people will think you are the police. Quote Link to comment Share on other sites More sharing options...
bzcat Posted May 5, 2021 Share Posted May 5, 2021 33 minutes ago, T-dubz said: This would be perfect with about a little more ground clearance and the ST grille. With the lights in the grille, I think lots of people will think you are the police. It actually uses the police Explorer grille. Ford just replaced the blue and red light bars with white LED in the grille. And according to the press release, it also has beefed up suspension from the police package (PIU has heavy duty shocks but not the lift) I really like the extra distance Ford went on Timberline. They started this trend a decade ago with FX4 but that seems so tame now with Tremor on the truck. I guess Timberline is basically Tremor but for SUVs. I think Edge and Escape Timberline will do well too but Ford probably won't do it until Bronco and Bronco Sport is well established in the market. Quote Link to comment Share on other sites More sharing options...
T-dubz Posted May 5, 2021 Share Posted May 5, 2021 47 minutes ago, bzcat said: I really like the extra distance Ford went on Timberline. They started this trend a decade ago with FX4 but that seems so tame now with Tremor on the truck. I guess Timberline is basically Tremor but for SUVs. I think Edge and Escape Timberline will do well too but Ford probably won't do it until Bronco and Bronco Sport is well established in the market. I’d say it’s more like the Active models Europe gets. Tremor seems to be up another level. Quote Link to comment Share on other sites More sharing options...
rmc523 Posted May 5, 2021 Share Posted May 5, 2021 1 hour ago, bzcat said: It actually uses the police Explorer grille. Ford just replaced the blue and red light bars with white LED in the grille. And according to the press release, it also has beefed up suspension from the police package (PIU has heavy duty shocks but not the lift) I really like the extra distance Ford went on Timberline. They started this trend a decade ago with FX4 but that seems so tame now with Tremor on the truck. I guess Timberline is basically Tremor but for SUVs. I think Edge and Escape Timberline will do well too but Ford probably won't do it until Bronco and Bronco Sport is well established in the market. That isn't the police grille, it's a unique one. This is the police one: 1 Quote Link to comment Share on other sites More sharing options...
tbone Posted May 5, 2021 Share Posted May 5, 2021 This model turned out better than I thought it would. Too bad they didn’t add adjustable ride height, to improve the ride height over their modest increase. It would also be nice if they had a motor to slot in between the 3.0 and the 2.3. 1 Quote Link to comment Share on other sites More sharing options...
bzcat Posted May 5, 2021 Share Posted May 5, 2021 3 hours ago, T-dubz said: I’d say it’s more like the Active models Europe gets. Tremor seems to be up another level. Active are FWD with no offroad stuff. Active is all just for looks like ST-line but with suspension lift (whereas ST-line has suspension drop). Timberline is definitely more like Tremor - standard 4WD, lifted suspension with offroad/beefier shocks, skid plates, limited slip differential, all terrain tires. Quote Link to comment Share on other sites More sharing options...
bzcat Posted May 5, 2021 Share Posted May 5, 2021 2 hours ago, rmc523 said: That isn't the police grille, it's a unique one. This is the police one: You are right. Timberline grille has an extra horizontal trim piece above the actual grille opening. Quote Link to comment Share on other sites More sharing options...
rmc523 Posted May 6, 2021 Share Posted May 6, 2021 7 hours ago, bzcat said: You are right. Timberline grille has an extra horizontal trim piece above the actual grille opening. The shapes are completely different. The Timberline's is squared off at the corners and terminates at the lower corners of the headlights, whereas the police (and other regular models) grille extends under the headlights. Quote Link to comment Share on other sites More sharing options...
T-dubz Posted May 6, 2021 Share Posted May 6, 2021 Is the interior green too? Ford calls it Deep Cypress, which appears to be a greenish gray color. 1 Quote Link to comment Share on other sites More sharing options...
IMSA-XJR9 Posted June 15, 2021 Share Posted June 15, 2021 Timberline is up on the Build & Price section now, FYI. Not too many options, which isn't a bad thing. Looking forward to test driving one . . . sometime this year. 3 Quote Link to comment Share on other sites More sharing options...
Buckin' Posted June 22, 2021 Share Posted June 22, 2021 Love that interior Quote Link to comment Share on other sites More sharing options...
Jamo_ Posted June 24, 2021 Share Posted June 24, 2021 On 5/5/2021 at 10:07 AM, T-dubz said: This would be perfect with about a little more ground clearance and the ST grille. Late to the party here but I too loved the green that I ended up ordering an ST in this same green. Now to get a build date for it. Now I wish I could get the green interior with it as well but 1 for 2 aint bad. Quote Link to comment Share on other sites More sharing options...
twintornados Posted September 10, 2023 Share Posted September 10, 2023 My local dealer has one "in transit" in Forged Green...told them to put my name on it when it comes in. I am interested. Quote Link to comment Share on other sites More sharing options...
