s&wowner Posted May 12, 2021 Share Posted May 12, 2021 I have a 2020 Ford Edge. I created a USB Flash with Music - all works well. My question is when I shut off the car - shouldn't the USB Flash shut off as well? My flash has a little led that lights up when in use. I noticed the other day that before I even started my ride - the led was lit. Does that mean it is drawing power regardless of whether the car is on and running? Thanks! Quote Link to comment Share on other sites More sharing options...
akirby Posted May 12, 2021 Share Posted May 12, 2021 Ports are powered for a short time after shutting off the vehicle. Nothing to worry about. Quote Link to comment Share on other sites More sharing options...
s&wowner Posted May 12, 2021 Author Share Posted May 12, 2021 The car was sitting for a while. I know the radio plays for a while after you shut off the car. But, the radio shuts off after you open the door. I noticed that the next day I got into the car and the USB's LED was flashing and I hadn't started the car. I will just remove it when not playing music from it...thanks for you response. Quote Link to comment Share on other sites More sharing options...
