fordlincolnfan Posted October 15, 2021 Share Posted October 15, 2021 Just bought a 2021 Corsair GT and when driving without the heat/ac on (at least I think its off) there is a lot of heat that seems to be coming out of driver and passenger feet vents or in that general area. Is this normal? Has anyone else had this happen? When I put the AC on it goes away. Thanks for any input. Quote Link to comment Share on other sites More sharing options...
bbf2530 Posted October 16, 2021 Share Posted October 16, 2021 (edited) On 10/15/2021 at 7:20 PM, fordlincolnfan said: Just bought a 2021 Corsair GT and when driving without the heat/ac on (at least I think its off) there is a lot of heat that seems to be coming out of driver and passenger feet vents or in that general area. Is this normal? Has anyone else had this happen? When I put the AC on it goes away. Thanks for any input. Hi flf. More information would be helpful. First, you say "(at least I think it is off)". So perhaps it would be helpful for you to check your Owners Manual and be sure you are actually turning the Climate Control system off when you "think it is off". In this way, we can rule out "User error". Next, what temperature do you have the Climate Control set to when you "think its off"? And what fan speed? It is an automatic temperature control system, so unless you physically turn it off by turning off the power button, it is still going to put out air at the fan speed selected, even if it is on low. And it may be warm air under certain circumstances (which are too numerous to list right now). Otherwise, if you have the system switched off and are still getting heat, or think something is wrong, make a service appointment to have it checked. Check your Owners Manual, get back to us with that information, and good luck. Edited October 17, 2021 by bbf2530 1 Quote Link to comment Share on other sites More sharing options...
