OREGUNFIRE Posted November 3, 2021 Share Posted November 3, 2021 I asked my dealer about getting stock looking fender flares for my F250. He said that the FORD ones are super expensive and that he recommends the bushwacker OEM style that are painted to match. https://www.bushwacker.com/oe-style-color-matched-flares/2021/ford/f-250-super-duty Does anyone have these and if so how have they held up? do the look stock? Or, does anyone have any that are painted to match from another source that are good. Thanks all Quote Link to comment Share on other sites More sharing options...
Power Kid Posted November 10, 2021 Share Posted November 10, 2021 BW work fine. Some have issue with the barely visible rubber type seal that sticks out a bit. Obviously not noticeable w black. I'm having same debate myself. Likely going w Ford units. Ill have them painted and added at bodyshop. No way I'm letting gravel chew up the bare fenders. One note if you go outside of BW or Ford it will be tough to find a mounded type mud guard. If you flap type will be easier. Not sure if that helped. Quote Link to comment Share on other sites More sharing options...
OREGUNFIRE Posted November 11, 2021 Author Share Posted November 11, 2021 On 11/9/2021 at 7:57 PM, Power Kid said: BW work fine. Some have issue with the barely visible rubber type seal that sticks out a bit. Obviously not noticeable w black. I'm having same debate myself. Likely going w Ford units. Ill have them painted and added at bodyshop. No way I'm letting gravel chew up the bare fenders. One note if you go outside of BW or Ford it will be tough to find a mounded type mud guard. If you flap type will be easier. Not sure if that helped. I agree, I drive on alot of gravel with snow covered roads and cant stand rock chips. The ford stock flares looks fine but I am going with the bush wackers as my dealership said $2k to install n paint to match. The bw is half that installed and it comes in my color (the gray metallic or what ever they call it). I also had to order wheel well liners as they dont come stock on a friggin $80k truck.. CRAZY.. Quote Link to comment Share on other sites More sharing options...
6.7zack Posted December 10, 2021 Share Posted December 10, 2021 Be careful with flares especially if you live in a salt belt area. The flares can vibrate and scrub the paint off the truck and cause issues not seen until its too late. Quote Link to comment Share on other sites More sharing options...
