James Decker Posted November 3, 2021 Share Posted November 3, 2021 I have a 07 Lincoln MKZ 3.5 engine.it wont crank ,hooked it to 2 different scanners both say TCM no communication. So i ran a wire from the starter turned the key on tuched the wire to the battery it fired right up .so i was thinking ok the ignition switch is bad, so i went to drive it to our local parts house, it takes off in second gear and doesn't shift out of second gear. Ok i know that the TCM if bad will not let it start, and it controls the shifting. So i got another TCM put it on still nothing, it did come off of a couple year newer car. I took it back got one off of the same year that the guy had literally just drove it in. And it doesn't work either. I have checked every ground,fuse,and relay i can check. Does anyone have any idea what the problem might be. Quote Link to comment Share on other sites More sharing options...
TexasRedneck Posted November 11, 2021 Share Posted November 11, 2021 A good scan tool is your friend. An experienced mechanic is your bosom buddy..... Quote Link to comment Share on other sites More sharing options...
