helicfi Posted January 3, 2022 Share Posted January 3, 2022 Hi guys, as the title says, i did a mis shift 5th to 2nd not really sure at what speed (mph) it pegged the tac… Not sure for how long a few seconds for sure… no check engine lights or unusual sounds… Is there any way to determine if i did damage? car has 17k on it. thanks so much for your input. Quote Link to comment Share on other sites More sharing options...
twintornados Posted January 3, 2022 Share Posted January 3, 2022 Is it making noises? If not, sounds like the rev limiter did its job.. Quote Link to comment Share on other sites More sharing options...
KeyLime Posted January 4, 2022 Share Posted January 4, 2022 I don't know the gearing numbers for the 2019, but on the 2021 (GT) shifting into 2nd at 90 mph yields about 8350 rpm. That's well above red line. I don't know if that's high enough to cause valve crash or other issues. If it sounds okay maybe you dodged a bullet. You might want to get on the S550 website and ask the question. There's a lot of hardcore motor heads there who mod and race and might know what the upper limit is. Here's the S550 link. https://www.mustang6g.com/forums/ Quote Link to comment Share on other sites More sharing options...
akirby Posted January 4, 2022 Share Posted January 4, 2022 On 1/3/2022 at 5:25 AM, twintornados said: Is it making noises? If not, sounds like the rev limiter did its job.. How would the rev limiter stop it? It’s the wheels turning the engine not the throttle control. Quote Link to comment Share on other sites More sharing options...
twintornados Posted January 5, 2022 Share Posted January 5, 2022 On 1/4/2022 at 9:37 AM, akirby said: How would the rev limiter stop it? It’s the wheels turning the engine not the throttle control. By shutting down fuel and spark to assist in preventing damage Quote Link to comment Share on other sites More sharing options...
akirby Posted January 5, 2022 Share Posted January 5, 2022 1 hour ago, twintornados said: By shutting down fuel and spark to assist in preventing damage Ok I guess that would help. Quote Link to comment Share on other sites More sharing options...
KeyLime Posted January 6, 2022 Share Posted January 6, 2022 For what it's worth I've seen comments on the Mustang6G forum that people have pushed Coyotes to 8000 rpm without problems. There are reports of oil pump gear failures at 8k, but the suggested cause is the rev limiter. When the engine bounces off the rev limiter at 8k there are harsh vibration loads transmitted to the OPG gears. Granted that seems to be an anecdotal explanation. Some of the hard core folks suggest setting the rev limit above the intended shift point (e.g 8200 rpm for 8000 rpm shifting) to avoid bumping it routinely. Quote Link to comment Share on other sites More sharing options...
akirby Posted January 6, 2022 Share Posted January 6, 2022 I drove a Porsche 911 GT3 on a racetrack. 4.0L naturally aspirated flat six with 504 hp and a 9000 rpm redline. It just kept revving and revving and the sound was glorious. 1 Quote Link to comment Share on other sites More sharing options...
tk421 Posted January 26, 2022 Share Posted January 26, 2022 Still mechanical overrev in any case, rods stretch, etc. At least you didn't get the full on money shift. Quote Link to comment Share on other sites More sharing options...
