kenneths Posted January 6, 2022 Share Posted January 6, 2022 Finally received my new 2022 F350 DRW King Ranch last Friday. I have a long driveway, so when I turn into my driveway I unbuckle my seatbelt, when I do the radio mutes and a warning pops up and says to buckle seat belt to unmute radio! Is there a way to turn this off? Also is there a way to turn off the 2 horn blast when you get out of the truck with it running and the key in your pocket? Quote Link to comment Share on other sites More sharing options...
akirby Posted January 6, 2022 Share Posted January 6, 2022 2 hours ago, kenneths said: Finally received my new 2022 F350 DRW King Ranch last Friday. I have a long driveway, so when I turn into my driveway I unbuckle my seatbelt, when I do the radio mutes and a warning pops up and says to buckle seat belt to unmute radio! Is there a way to turn this off? Also is there a way to turn off the 2 horn blast when you get out of the truck with it running and the key in your pocket? You must have enabled the MyKey function. Use the other fob and turn off MyKey. That will fix the seatbelt issue. You can turn off the double honk with forscan but it’s easier to just not shut the door all the way. 1 Quote Link to comment Share on other sites More sharing options...
IUEC135ELEVATOR Posted January 7, 2022 Share Posted January 7, 2022 4 hours ago, akirby said: You must have enabled the MyKey function. Use the other fob and turn off MyKey. That will fix the seatbelt issue. You can turn off the double honk with forscan but it’s easier to just not shut the door all the way. I have that activated on my truck on purpose forces me to buckle up.... And never use the key fob that I use to activate the Mykey. Also On my daily friver truck I have the speed limit set to 70 miles an hour since new.... I figured that way I always buckle up and I never go over the speed limit on the interstate. Quote Link to comment Share on other sites More sharing options...
FL Lariat Driver Posted January 7, 2022 Share Posted January 7, 2022 8 hours ago, kenneths said: Finally received my new 2022 F350 DRW King Ranch last Friday. I have a long driveway, so when I turn into my driveway I unbuckle my seatbelt, when I do the radio mutes and a warning pops up and says to buckle seat belt to unmute radio! Is there a way to turn this off? Also is there a way to turn off the 2 horn blast when you get out of the truck with it running and the key in your pocket? I don't think there is any way, other than ForScan, to eliminate the double honk when you exit the vehicle while it is running IF you have the Intelligent access/push-button start and you take the fob out with you. If I don't want my truck to honk at me, I leave the fob in the truck when I get out with the engine running. Quote Link to comment Share on other sites More sharing options...
akirby Posted January 7, 2022 Share Posted January 7, 2022 3 ways to eliminate the honk without forscan leave fob in vehicle (lock with keypad if necessary) turn engine off don’t shut the door all the way 3 Quote Link to comment Share on other sites More sharing options...
FL Lariat Driver Posted January 8, 2022 Share Posted January 8, 2022 On a truck with intelligent access/push button start, not closing the door all the way will not prevent the horn honk if the fob leaves the vehicle while the engine is running. The OP says he has the key in his pocket so that seems like he isn't using a conventional key but does have the intelligent access fob. On my intelligent access truck, with the engine running, if the fob gets more than about two feet outside the truck, with the door open or closed, the horn honks. I might try to partly close the door next time and see if that prevents the honk. Quote Link to comment Share on other sites More sharing options...
akirby Posted January 8, 2022 Share Posted January 8, 2022 2 hours ago, FL Lariat Driver said: On a truck with intelligent access/push button start, not closing the door all the way will not prevent the horn honk if the fob leaves the vehicle while the engine is running. The OP says he has the key in his pocket so that seems like he isn't using a conventional key but does have the intelligent access fob. On my intelligent access truck, with the engine running, if the fob gets more than about two feet outside the truck, with the door open or closed, the horn honks. I might try to partly close the door next time and see if that prevents the honk. Well neither of my intelligent access vehicles work that way. Leave the door open and it doesn’t honk. 2013 Fusion (gone) and a 2016 MKX. Quote Link to comment Share on other sites More sharing options...
road turtle Posted January 8, 2022 Share Posted January 8, 2022 8 hours ago, akirby said: Well neither of my intelligent access vehicles work that way. Leave the door open and it doesn’t honk. 2013 Fusion (gone) and a 2016 MKX. Superduty works the same way. Quote Link to comment Share on other sites More sharing options...
kenneths Posted January 12, 2022 Author Share Posted January 12, 2022 Thanks for all of the replies. I will remove the my key and see if that fixes the radio issue. I guess I will just have to learn to deal with the double horn issue since I don't have forScan. Quote Link to comment Share on other sites More sharing options...
akirby Posted January 12, 2022 Share Posted January 12, 2022 1 hour ago, kenneths said: Thanks for all of the replies. I will remove the my key and see if that fixes the radio issue. I guess I will just have to learn to deal with the double horn issue since I don't have forScan. After you remove MyKey see if not closing the door all the way eliminates the double honk. That works on all vehicles unless they changed something recently. Quote Link to comment Share on other sites More sharing options...
