ohsown Posted January 8, 2022 Share Posted January 8, 2022 (edited) The rear washer on my 22 explorer has glitch that makes me cringe every time I use it. When I push the stalk to activate the washer/wiper, the spray function doesn't start until after the wiper has made at least 1 1/2 passes. I thought maybe the fluid was draing back between uses but trying it as little as 2 minutes later has the same result. Is there a checkvalve involved? Are others having a similar experience? I've found reports of other makes ( BMW, Audi ) but nothing on Explorers or other Fords. Edited March 5, 2022 by ohsown spelling Quote Link to comment Share on other sites More sharing options...
Sceve Posted January 20, 2022 Share Posted January 20, 2022 There is a check valve that is built into the sprayer nozzle itself, but most of the rear sprayers tend to drain back pretty quickly because of their location. You may have luck getting your dealer to replace it under warranty if you are still under bumper to bumper, but it may not get a ton better. 1 Quote Link to comment Share on other sites More sharing options...
ohsown Posted January 25, 2022 Author Share Posted January 25, 2022 Thanks for this, I havent been able to get any info on it. I did speak to the dealer last week but havent heard back yet. Quote Link to comment Share on other sites More sharing options...
ohsown Posted March 5, 2022 Author Share Posted March 5, 2022 Took my Explorer back to the dealer again for the sprayer issue. The first time they told me not spraying when the wiper starts is normal. They maintain there is no check valve in the nozzle. Gave me a loaner for the day, gratis. Took it apart and they tell me the hose doesn't seem to kinked and connection is fine. They will now order a new nozzle and try that. I have no idea what the nozzle might cost but do know round trip with my vehicle and another with the loaner runs about 25 canadian pesos, not to mention 2 hours on the road. The saga continues. Quote Link to comment Share on other sites More sharing options...
ohsown Posted March 25, 2022 Author Share Posted March 25, 2022 Well replacing the rear window sprayer nozzle made to improvement to the operation. Their service tech said that there was a problem a while ago with the F 150's front camera washer for which a tsb was issued, that perhaps the rear camera washer on my explorer might have a similar problem. Parts on order. I told him we will give this a shot but next step will be replacing lines from pump back. Time will tell. Quote Link to comment Share on other sites More sharing options...
ohsown Posted April 19, 2022 Author Share Posted April 19, 2022 Yesterday, Apr. 18, 4th trip to dealership for spray delay problem to install new spray nozzle for the rear camera washer. The thinking being this may be a similar situation to the front camera washer that was a problem on ford pickups due to leaking washer fluid from the nozzle. This attempt failed to remedy the delay problem with fluid draining back out of the line. Again on washer activation air is forced out of the hatch window washer nozzel while the wiper is passing dry across the glass before fluid starts to spurt from the nozzel then finally spraying. Again, from a different service rep. I was told this is normal operation. The dealership owner and I checked a new Aviator he has on the lot ( no Explorers available ) that had not moved in over a week and again confirmed it is not normal as the washer sprayed as the wiper started to move. We have done this check together on a new Explorer prior to this with the same instant spray result. He is going to contact Ford through some messaging process they have for tech sssistance ( the name eluded him ) for their guidance as to a solution. The upside, when I asked him the trade in value his reply was that it was probably more than I paid but I'm not there yet! Quote Link to comment Share on other sites More sharing options...
ohsown Posted May 28, 2022 Author Share Posted May 28, 2022 Just about 6 wks gone since last trip to dealer. My Explorer has sat for the last week due to my being laid up. Taking it out first drive since (raining) I found the spray function for the windshield took 4 or 5 seconds before spraying. Jogging my curiosity I called and found that a rear washer pump has been ordered but no eta. I told him about the front and he confirmed something I had read about on older models prior to the 2020 refresh, but I found nothing about on models sincebeing there are 2 washer motors in the reservoir, the rear sitting higher. So if you notice a lack of spray for the rear check the fluid level. I had already ruled this out months ago. Something new is the part number is different now so something has changed. A stroke of luck, the 2 pumps and reservoir are available as a complete unit so this is now on order with no eta available and its up to the wizardry of the supply chain overseers. Quote Link to comment Share on other sites More sharing options...
ohsown Posted July 1, 2022 Author Share Posted July 1, 2022 Last week my dealer called to set up a service date as the washer reservoir with internal pumps had arrived, yesterday was the day, 8 a.m.. A free loaner was provided as per usual. I heard back from them after lunch with the news I've been waiting for, namely, having finished the installation, the spray activated as soon as the control was pushed. Letting it sit over the noon hour proved to have the same result with no apparent loss of prime to front or rear washer spray. I tried it again this morning after it sat for 17 hours and had the same instant spray operation. It took some convincing to sway them from their initial "thats normal" mindset along with supply chain delays but finally job done, hopefully with no further issues or goosebumps from a wiper scraped across road grime on dry glass. Quote Link to comment Share on other sites More sharing options...
