menasco Posted January 20, 2022 Share Posted January 20, 2022 (edited) While waiting on my 22 f250 I have been researching wheels/tires. I already have the carli 2.5 pintop system with deaver rear springs and have not made up my mind on wheels. My current truck a 15 f150 had a 4" lift with maxxis razr at 35x12.5x18 and vision machined wheel. The truck I have on order is the same color as my f150, I plan on putting on bronze wheels. I have come back to this Fuel Covert wheel several times. My plan is to get them in 18x9 and put on 37x12.5 Maxxis RAZR AT. Anyone running these wheels please share some photos. I like the stance of this truck but 40"'s are too big. Edited January 20, 2022 by menasco 1 Quote Link to comment Share on other sites More sharing options...
Overthebars Posted January 20, 2022 Share Posted January 20, 2022 Thise wheels look pretty nice Quote Link to comment Share on other sites More sharing options...
Mefly2 Posted January 20, 2022 Share Posted January 20, 2022 Very nice! Quote Link to comment Share on other sites More sharing options...
FordySumthin Posted January 21, 2022 Share Posted January 21, 2022 8 hours ago, menasco said: While waiting on my 22 f250 I have been researching wheels/tires. I already have the carli 2.5 pintop system with deaver rear springs and have not made up my mind on wheels. My current truck a 15 f150 had a 4" lift with maxxis razr at 35x12.5x18 and vision machined wheel. The truck I have on order is the same color as my f150, I plan on putting on bronze wheels. I have come back to this Fuel Covert wheel several times. My plan is to get them in 18x9 and put on 37x12.5 Maxxis RAZR AT. Anyone running these wheels please share some photos. I like the stance of this truck but 40"'s are too big. I like these wheels a lot. Not sure if you’re in rougher terrain or mainly do city driving, but those would be a chore to clean. All the angles and holes to get in and out of. Beautiful wheel though! Quote Link to comment Share on other sites More sharing options...
MT350 Posted January 21, 2022 Share Posted January 21, 2022 Good choice on the wheels. I went with them because they were rated the heaviest in an 18 inch at close to zero offset. The Method HD’s are a plus 18 offset unless you go with a 17 inch wheel like Carli recommends. Mine are a plus 3 offset and it puts them just at the outside of the wheel well opening. They are a little busy but I always detail with a pressure washer so not a problem. Tires are currently 35’s because of a good deal on them but will run 37’s when these run out. Please post pics when you’re truck is here and all set up. 1 Quote Link to comment Share on other sites More sharing options...
menasco Posted March 22, 2022 Author Share Posted March 22, 2022 Finally the truck is finished. Carli 2.5 pintop, deaver leafs, fuel covert 18”, wheels, 37” ridge grappler (maxxis does not make a razor at 37x18), Baja designs lights, dual arb, bed liner, and bakflip tonneau. First trip was to north padre national seashore for spring break. 60 miles south to the Mansfield cut fuel covert 18x9 with 37x12.5x18 ridge grappler, did well in the sand @ 30 psi our campsite @ mile 8, perfect. No neighbors! 1 Quote Link to comment Share on other sites More sharing options...
themadmonk Posted March 22, 2022 Share Posted March 22, 2022 Looks good. What offset did you get? I have no idea what that even means in wheels. I'm more than likely going to get them in 20" as that's size tire on my truck currently. Quote Link to comment Share on other sites More sharing options...
menasco Posted March 22, 2022 Author Share Posted March 22, 2022 -12 5.470 https://www.fueloffroad.com/wheel/13343/fuel-1-piece-wheels-covert-d696/?finish=4434&part=D69618901745 Quote Link to comment Share on other sites More sharing options...
MT350 Posted March 22, 2022 Share Posted March 22, 2022 12 hours ago, menasco said: Finally the truck is finished. Carli 2.5 pintop, deaver leafs, fuel covert 18”, wheels, 37” ridge grappler (maxxis does not make a razor at 37x18), Baja designs lights, dual arb, bed liner, and bakflip tonneau. First trip was to north padre national seashore for spring break. 60 miles south to the Mansfield cut fuel covert 18x9 with 37x12.5x18 ridge grappler, did well in the sand @ 30 psi our campsite @ mile 8, perfect. No neighbors! And that’s what a well researched truck build looks like. Excellent work and thanks for posting the follow up pics. PS - I’m jealous of your suspension setup. I’ll bet it drives amazing off road. Quote Link to comment Share on other sites More sharing options...
