jmac5058 Posted January 20, 2022 Share Posted January 20, 2022 My regular cab SRW F 350 I ordered without the camper special does that mean it cant legaly have a slide on camper put on ? Just came across a paper in thr glove box that said not to . The payload is 4393 lbs . Quote Link to comment Share on other sites More sharing options...
IUEC135ELEVATOR Posted January 21, 2022 Share Posted January 21, 2022 Don't see why you couldn't people have been putting campers on trucks long before there was such thing as a camper package. So the 2000 Chevy truck that you're parked next to that does not have a camper package is allowed to carry it and your truck which has a ton more capacity and stability would not be allowed to... that does not make sense. ( but then again laws rules and regulations do not always makes sense) Quote Link to comment Share on other sites More sharing options...
Laws Posted January 21, 2022 Share Posted January 21, 2022 I ordered mine with the camper package. I think the only thing that you might get trouble on is if you lost control due to the higher COG, but if you add a rear sway bar I cant see a court holding you criminally negligible or personally liable from a recklessness standpoint. As always stay within weight and you should be good to go. Quote Link to comment Share on other sites More sharing options...
mww982 Posted January 21, 2022 Share Posted January 21, 2022 13 hours ago, Laws said: I ordered mine with the camper package. I think the only thing that you might get trouble on is if you lost control due to the higher COG, but if you add a rear sway bar I cant see a court holding you criminally negligible or personally liable from a recklessness standpoint. As always stay within weight and you should be good to go. Same here, not sure if I will ever get a slide-in but wanted the option. Quote Link to comment Share on other sites More sharing options...
