bobbyd Posted June 14, 2022 Share Posted June 14, 2022 My daughter's 2019 Edge has a 2.0 Eco boost engine. The dealer recommended we have the Direct Injection Cleaning done with her oil change. ($100) I heard from others it could affect the turbo during the cleaning. Any suggestions. Thanks! Quote Link to comment Share on other sites More sharing options...
bbf2530 Posted June 14, 2022 Share Posted June 14, 2022 (edited) 2 hours ago, bobbyd said: My daughter's 2019 Edge has a 2.0 Eco boost engine. The dealer recommended we have the Direct Injection Cleaning done with her oil change. ($100) I heard from others it could affect the turbo during the cleaning. Any suggestions. Thanks! Hi bobbyd. Ford specifically tells owners not to perform injection tract cleaning services (i.e Sea Foam, CRC etc.) on their EcoBoost and Lincoln T engines. Yes, it can damage the turbo impellers, housings, seals, catalytic converters etc. Do not do it. Good luck. Edited June 14, 2022 by bbf2530 1 Quote Link to comment Share on other sites More sharing options...
bobbyd Posted June 15, 2022 Author Share Posted June 15, 2022 16 hours ago, bbf2530 said: Hi bobbyd. Ford specifically tells owners not to perform injection tract cleaning services (i.e Sea Foam, CRC etc.) on their EcoBoost and Lincoln T engines. Yes, it can damage the turbo impellers, housings, seals, catalytic converters etc. Do not do it. Good luck. Thanks bbf2530 for your response. I don't want to damage the components but was wondering if there are any alternatives to this carbon issue on Direct Injection engines? At least , your timing was perfect, since we get our oil change on Thursday. Quote Link to comment Share on other sites More sharing options...
bbf2530 Posted June 15, 2022 Share Posted June 15, 2022 33 minutes ago, bobbyd said: Thanks bbf2530 for your response. I don't want to damage the components but was wondering if there are any alternatives to this carbon issue on Direct Injection engines? At least , your timing was perfect, since we get our oil change on Thursday. Hi bobbyd. Currently, the only Ford approved method of cleaning the valves is to remove the intake and manually clean them (i.e. walnut blasting etc). And just to avoid confusion for others: Intake cleaning services are generally okay to use on Direct Injection engines (GDI/Gas Direct Injection). GDI engines are not turbocharged, only direct injected. Although there is still the issue of possible catalytic converter damage. However, intake cleaning services can not be used on Gas Turbocharged Direct Injection engines (GTDI). It is the turbocharger/turbochargers which makes the difference. Good luck. 1 Quote Link to comment Share on other sites More sharing options...
akirby Posted June 15, 2022 Share Posted June 15, 2022 If you’re not having problems you shouldn’t worry about it. Daughter’s 2014 Escape 2.0LEB has 100k miles and no issues. But the real solution is to remove the head and clean the valves outside the engine. 1 Quote Link to comment Share on other sites More sharing options...
