Lima Posted January 30, 2023 Share Posted January 30, 2023 Trailer brake gain is on 10 and will not move ! I’ve plugged my trailer in and still on 10 will not move! Any help would be appreciated! Quote Link to comment Share on other sites More sharing options...
AggieF350 Posted January 31, 2023 Share Posted January 31, 2023 3 hours ago, Lima said: Trailer brake gain is on 10 and will not move ! I’ve plugged my trailer in and still on 10 will not move! Any help would be appreciated! I’m assuming you used the arrows up and down and still won’t move? Quote Link to comment Share on other sites More sharing options...
Lima Posted January 31, 2023 Author Share Posted January 31, 2023 I’m not even seeing the arrows! I’m probably doing something wrong I hope! I’m going to go in and delete the saved trailer and start over. The truck is recognizing the trailer lights are working just can’t adjust the brakes. Thanks for responding! Quote Link to comment Share on other sites More sharing options...
AggieF350 Posted January 31, 2023 Share Posted January 31, 2023 52 minutes ago, Lima said: I’m not even seeing the arrows! I’m probably doing something wrong I hope! I’m going to go in and delete the saved trailer and start over. The truck is recognizing the trailer lights are working just can’t adjust the brakes. Thanks for responding! I would try and delete the trailer then if it doesn’t work I would take it to the dealer.. I found this online also https://fordauthority.com/2022/04/ford-f-series-recalled-over-trailer-brake-controller-safety-issue/amp/ Quote Link to comment Share on other sites More sharing options...
Lima Posted February 1, 2023 Author Share Posted February 1, 2023 Thanks for the info! I did delete the trailer and tried again but still no luck. Going to the dealership Thursday. 1 Quote Link to comment Share on other sites More sharing options...
AggieF350 Posted February 4, 2023 Share Posted February 4, 2023 On 1/31/2023 at 7:03 PM, Lima said: Thanks for the info! I did delete the trailer and tried again but still no luck. Going to the dealership Thursday. What did you find out from the dealer? Quote Link to comment Share on other sites More sharing options...
ScottK1 Posted February 9, 2023 Share Posted February 9, 2023 (edited) On 1/31/2023 at 6:27 AM, Lima said: I’m not even seeing the arrows! I’m probably doing something wrong I hope! I’m going to go in and delete the saved trailer and start over. The truck is recognizing the trailer lights are working just can’t adjust the brakes. Thanks for responding! What do you mean you're not seeing them? They are buttons on the dash, with the lever. Edited February 9, 2023 by ScottK1 1 Quote Link to comment Share on other sites More sharing options...
Lima Posted February 10, 2023 Author Share Posted February 10, 2023 Took truck to dealership ford left out the fuse! Trailer brake gain can be adjusted now 1 Quote Link to comment Share on other sites More sharing options...
AggieF350 Posted February 10, 2023 Share Posted February 10, 2023 31 minutes ago, Lima said: Took truck to dealership ford left out the fuse! Trailer brake gain can be adjusted now Oh awesome.. Quote Link to comment Share on other sites More sharing options...
