KevR Posted February 22, 2023 Share Posted February 22, 2023 I noticed the other day when my gas engine turns on I can't rev the engine while In park. When you require an oil change or emissions test later on in the vehicles life, you will need to force the engine on and rev at a certain rpm. Is there any trick to doing this with the Ford Escape PHEV's? Quote Link to comment Share on other sites More sharing options...
akirby Posted February 22, 2023 Share Posted February 22, 2023 2 hours ago, KevR said: I noticed the other day when my gas engine turns on I can't rev the engine while In park. When you require an oil change or emissions test later on in the vehicles life, you will need to force the engine on and rev at a certain rpm. Is there any trick to doing this with the Ford Escape PHEV's? They use the obd-II port to check emissions and you do t need to do that for an oil change, 1 Quote Link to comment Share on other sites More sharing options...
