2016 MKS and Android Auto
RickD1245
Can't seem to get Android Auto working in my 2016 MKS.  I have latest SYNC3 Version 3.0 Build 23219 and I have tried both of the USB ports under the arm rest.   AA works fine in my 2016 F150 but doesn't connect in the MKS.  Using a good Anker cable.
Does your phone at least charge when you plug it into the USB port?  If not the USB ports could be bad.
Also how technical are you?  You could go check out cyan labs and download their tool and upgrade your unit to Sync 3.4 which may fix this issue.
