Ford Recall Troubles
13 hours ago, 7Mary3 said:
I was around for that one, and that was not always case.  Ford had a notoriosly junky and wear-prone steering column shifter, sloppy linkage, and a weak detent spring in the transmission.  They could fall out of 'park' from vibration with the engine idling, but true you shouldn't leave a vehicle idling unattended with the parking brake not set.
That’s not how I read it.  It said that if the shifter wasn’t put all the way in park then it could be jarred out of park.  But it sounded to me like once it was in park it was ok.  But maybe I misread it.
4 hours ago, akirby said:
Cost and resources to change over.  Huge impact on supply chain contracts old and new.  I think the EV skunkworks project really demonstrated how much this was needed.
The Skunkworks has actually accomplished something? Wow! All I've heard is a lot of talk from Farley.
  • Haha 1
If the shift linkage was tight and not worn excessively I think that would be the case, the transmission was not all the way in 'park'.  I saw so many that were worn to the point when the lever was in park all the way the transmission valve body was not.  I remember seeing an old Granada tearing through a parking lot in reverse with no one at the wheel.  Luckily a Dodge truck stopped in cold!  When I used to work on old Fords I would put a wheel chock behind the back wheel........
6 hours ago, Bob Rosadini said:
So after repeated "sometimes it works, sometimes it doesn't" I guess I'll have to take it to dealer.  Speaking of system updates, I assume you don't get a message when these are done?
I never got any update msg on the truck when I had a tranny TSB done on my Ranger, just a note on the repair bill saying in part that a refresh had been done.
4 hours ago, rmc523 said:
I keep seeing a lot of reports of Ford sending out new recalls to redo prveious incorrectly done recalls
I would like to know if anyone was fired for this travesty.  The number of headlines involving Ford recalls is embarrassing, and isn’t a recipe for increasing sales.
It’s a systemic problem, not one or two people.
Ford needs to do some soul searching.  These issues have been going on entirely too often and too long.  Real leaders take responsibility for problems, so I guess no bonus for any managers this year.
