BigDZ Posted March 19, 2025 Share Posted March 19, 2025 (edited) I own a 2021 Ford Expedition and have had the freon replaced 3X and finally found a mechanic that diagnosed the problem which is a defective evaporator core. The owner of the shop has another one in his shop with the same issue (they replace these cores on a regular basis) and though no bulletins have been issued, let alone recalls, he claims that Ford Dealers are aware of this issue but do not cover the cost. So my question is simple, do any other owners of F150, Expeditions, Navigators have this issue? Thank you! UPDATE--I had to have my a/c evaporator core replaced, and it was clearly leaking which is alarming at only 30,000 miles and cost me almost $5000.00. This requires the entire dash to be removed and another freon charge. Based on several Ford dealer mechanics along with a couple of privately owned shops, this is a very common issue. I'll add pictures since I kept the core. The telltale sign is if your vehicle smells musty inside, you have a leak! Edited April 15, 2025 by BigDZ Update Quote Link to comment Share on other sites More sharing options...
