Idan Posted November 9, 2025 Share Posted November 9, 2025 I have a 2012 Ford Focus. I had to replace the alternator a few months ago, which I did myself. The alternator has three bolts—two on top and one on the bottom (the pivot bolt) —and I tightened the bottom bolt all the way when I screwed it in. About two months later, I started hearing a metallic noise while driving and discovered that the bolt had almost completely loosened (but could not be pulled out). I screwed it back in and found that at the end of the threading, it doesn't fully tighten but instead just spins. Now it slowly loosens again and again, and I also have that metallic noise which I don't like hearing. Does anyone have an idea what I can do to keep it from unscrewing? Thanks in advance everyone. Quote Link to comment Share on other sites More sharing options...
twintornados Posted November 9, 2025 Share Posted November 9, 2025 8 hours ago, Idan said: I have a 2012 Ford Focus. I had to replace the alternator a few months ago, which I did myself. The alternator has three bolts—two on top and one on the bottom (the pivot bolt) —and I tightened the bottom bolt all the way when I screwed it in. About two months later, I started hearing a metallic noise while driving and discovered that the bolt had almost completely loosened (but could not be pulled out). I screwed it back in and found that at the end of the threading, it doesn't fully tighten but instead just spins. Now it slowly loosens again and again, and I also have that metallic noise which I don't like hearing. Does anyone have an idea what I can do to keep it from unscrewing? Thanks in advance everyone. The mounting hole it threads into is stripped out - either tap it a size larger or slip a nut behind it if it is open on the other end and with a longer bolt, tighten it up. Quote Link to comment Share on other sites More sharing options...
