Diesel Dude Posted December 5, 2025 Share Posted December 5, 2025 My 2024 F350 thinks my tailgate is open all of the time, therefore when I back up, the rear parking sensors are disabled. The tailgate dash light stays on constantly. It was intermittent at first, but I’m not able to do anything to clear it. I am not familiar with the setup to know if it’s a sensor or physical switch. Any help or troubleshooting advice is greatly appreciated. I’ve tried searching YouTube but either I’ve chosen the wrong wording, or there’s no video covering the topic. Thanks a lot! Quote Link to comment Share on other sites More sharing options...
akirby Posted December 6, 2025 Share Posted December 6, 2025 Sensor. See if it's unplugged Quote Link to comment Share on other sites More sharing options...
twintornados Posted December 6, 2025 Share Posted December 6, 2025 Since it is still under warranty - bring it to the dealer? Quote Link to comment Share on other sites More sharing options...
Hillbilly Auto Supply Posted December 8, 2025 Share Posted December 8, 2025 Much more likely to be a tailgate sensor/latch issue or wiring issue than a software issue. Lower the tailgate completely. Look at the two latch clips on the tailgate ends that grab the bed-side striker pins. Flip each latch to its closed position to make the sensors think the gate is shut. Then key the engine on. If that fixes the issue, then you're dealing with a latch alignment or striker pin adjustment problem. If the light stays on, then you're likely looking at a bad sensor in the latch/actuator, or maybe wiring. Quote Link to comment Share on other sites More sharing options...
B767capt Posted February 6 Share Posted February 6 I had this issue on my 2024 F250. It drove me nuts. I could see the top left corner of the tailgate just ever so slightly out compared to the upper right corner. It started about 6 months after I bought it. I was thinking the lock in the tailgate wasn't quite closing 100%. The post that the lock wraps around is adjustable, so I loosened it and moved it out, or towards myself to see if the lock would wrap around the post more. I worked, and the corner of the tailgate was more flush. I haven't had that light in 6 months. Quote Link to comment Share on other sites More sharing options...
