rmc523 Posted June 11 Author Share Posted June 11 https://www.carscoops.com/2026/06/ford-expedition-trim-recall/ The automaker is recalling 548,463 Expeditions from the 2018 through 2024 model years after discovering that chrome plating on the center console can bubble, peel, and separate from the underlying material. When that happens, the trim can develop sharp edges capable of causing injuries. 1 Quote Link to comment Share on other sites More sharing options...
Joe771476 Posted June 11 Share Posted June 11 4 hours ago, rmc523 said: https://www.carscoops.com/2026/06/ford-expedition-trim-recall/ The automaker is recalling 548,463 Expeditions from the 2018 through 2024 model years after discovering that chrome plating on the center console can bubble, peel, and separate from the underlying material. When that happens, the trim can develop sharp edges capable of causing injuries. Yeah I just saw that. My buddy picked me up in his BMW and when I closed the door, my hands got all black and sticky! I told him and he just sloughed it off. When I got home I searched it and lo and behold it is a problem with certain BMW's. The heat melts the plastic interior grab handle! Quote Link to comment Share on other sites More sharing options...
rmc523 Posted June 12 Author Share Posted June 12 2 hours ago, Joe771476 said: Yeah I just saw that. My buddy picked me up in his BMW and when I closed the door, my hands got all black and sticky! I told him and he just sloughed it off. When I got home I searched it and lo and behold it is a problem with certain BMW's. The heat melts the plastic interior grab handle! Yes, my mom had an '07 335i convertible and its handles peeled several times. She had the beige interior, and it did the same thing....she had to have them recoated a few times. Quote Link to comment Share on other sites More sharing options...
Motorpsychology Posted June 12 Share Posted June 12 17 hours ago, rmc523 said: https://www.carscoops.com/2026/06/ford-expedition-trim-recall/ The automaker is recalling 548,463 Expeditions from the 2018 through 2024 model years after discovering that chrome plating on the center console can bubble, peel, and separate from the underlying material. When that happens, the trim can develop sharp edges capable of causing injuries. ...Ford could issue two pair of leather work gloves to owners of affected vehicles... Quote Link to comment Share on other sites More sharing options...
twintornados Posted June 12 Share Posted June 12 (edited) 17 hours ago, rmc523 said: https://www.carscoops.com/2026/06/ford-expedition-trim-recall/ The automaker is recalling 548,463 Expeditions from the 2018 through 2024 model years after discovering that chrome plating on the center console can bubble, peel, and separate from the underlying material. When that happens, the trim can develop sharp edges capable of causing injuries. Had a similar issue on my 2006 Ford Fusion - the chrome "plating" on the interior plastic door handle pull had bubbled and began to peel causing a sharp edge to form from the plating....I replaced the handle and continued on... Edited June 12 by twintornados Quote Link to comment Share on other sites More sharing options...
fordmantpw Posted June 12 Share Posted June 12 17 minutes ago, twintornados said: Had a similar issue on my 2006 Ford Fusion - the chrome "plating" on the interior plastic door handle pull had bubbled and began to peel causing a sharp edge to form from the plating....I replaced the handle and continued on... Yeah, there comes a point when people have to realize that a vehicle isn't perfect and will wear out. I mean, some of these are 8 years old! Seriously, things wear out over time, especially things that are used nearly 100% of the time the car is in use. What's next, recalls because tires wear out after 10 years and 200k miles? A safety issue because brakes don't last 15 years? Geez! 2 Quote Link to comment Share on other sites More sharing options...
akirby Posted June 12 Share Posted June 12 A recall for a wear item that doesn't affect driving is ridiculous. 3 Quote Link to comment Share on other sites More sharing options...
rmc523 Posted June 12 Author Share Posted June 12 Ford’s Recalling A Quarter-Million Cars Because It Can’t Recall If It Fixed Them In 2018 | Carscoops Ford is recalling more than a quarter-million Focus models because it can’t confirm that an earlier safety recall from October 2018 was actually completed correctly. The new recall, 26S40, covers 255,404 Ford Focus vehicles from the 2012-2018 model years that were previously repaired under recall 18S32 (NHTSA campaign 18V735). According to Ford, some vehicles were recorded as having received the required Powertrain Control Module software update even though the correct software may never have been installed. That means the original defect could still be lurking beneath the surface. Quote Link to comment Share on other sites More sharing options...
rmc523 Posted June 16 Author Share Posted June 16 2024 Ford Explorer Recalled Over Rollaway Risk The defect: in affected vehicles, the park system may be damaged by an erroneous powertrain control module (PCM) reset while the vehicle is in motion and not shift into "Park," potentially resulting in a vehicle rollaway risk. Ford is aware of 27 warranty claims potentially related to this condition. Ford is not aware of any accidents, injuries, or fires related to this condition. The hazards: if the vehicle does not shift into "Park," it may roll away and result in unintended vehicle movement, thereby increasing the risk of injury or a crash. Affected vehicles: select 2024 Ford Explorer models built between January 23rd, 2024, and April 25th, 2024. Number of vehicles affected: 58 The fix: a dealer will inspect the vehicle for park system damage. If damage is found, it will be repaired with new components as appropriate. This service will be performed at no charge to 2024 Ford Explorer owners. Quote Link to comment Share on other sites More sharing options...
rmc523 Posted June 17 Author Share Posted June 17 Ford Botched Repairs On Over 125,000 Vehicles, Leading To Four New Recalls | Carscoops Since there are so many recalls, we’ll keep things brief and note that the automaker is recalling 5,252 vehicles for a transmission clutch that can fracture and leak fluid. This increases the risk of a fire. 1) The new recall impacts the 2015-2018 Focus and 2013-2016 Fusion, which were “repaired incorrectly” under two previous campaigns. 100% of the vehicles are believed to be impacted as they didn’t get the correct software update installed. 2) The second recall involves 10,742 F-150s from the 2018 model year. The government says quickly moving the shifter can cause a loss of the gear indicator on the instrument cluster. It can also lead to “momentary selection of an unintended gear, such as Reverse or Neutral.” These vehicles were also incorrectly repaired and need to get their powertrain control module software updated to address the issue. 3) Continuing with the recall redux, 18,124 crossovers have windows that can pinch occupants because their automatic reversal system can malfunction. The problem impacts the 2017 Escape, and the government says the “power-operated windows may exert excessive force when encountering an object, before they automatically reverse.” This means they fail to comply with federal safety standards. As a result of a previously botched recall, they need to get their power window operating software updated. 4) The fourth recall impacts 91,198 F-150s from 2018-2020. They have daytime running lights that can remain fully bright instead of dimming to parking lamps as intended when switching from “Auto lamps” to “Headlamps On.” They run afoul of federal safety standards and were also incorrectly repaired as part of a previous recall. This means owners need to return to the dealership to have the body control module software updated – hopefully correctly. 5) Since four recalls about previous campaigns are a little boring, Ford decided to spice things up with a brand-new recall involving Explorers that can rollaway. The 2024 models are equipped with 2.3-liter EcoBoost engines. The issue is a tad complex, but the safety recall report said the crossovers can experience unintentional powertrain control module resets. If these occur while the vehicle is in motion, the parking system can become damaged. This can prevent the vehicle from shifting into park, which can cause it to unexpectedly rollaway. The problem is being blamed on a Diagnostic Identifier data packet that is too large for the Powertrain Control Module to handle. This can result in buffer overflow, which trips a reset. The reset causes the transmission to shift to park, even if the vehicle is in motion. Ford became aware of the issue in May and has found 27 warranty claims potentially related to the issue. However, there have been no accidents or injuries. As part of the recall, dealers will inspect the parking system for damage and replace parts as needed. Quote Link to comment Share on other sites More sharing options...
rmc523 Posted June 18 Author Share Posted June 18 Another day, another recall: Ford Escape Recalled Yet Again Over Windows That Could Pinch Fingers - Autoblog The recall affects 18,124 Ford Escape vehicles from the 2017 model year. These models were originally recalled for the same issue in August 2016, but the software fix implemented at that time has been deemed inadequate. “If the window closing force exceeds the regulatory requirement, it could increase the risk of injury,” said Ford in the recall report, which was shared by the NHTSA. Although the windows will automatically reverse and open again when encountering an object, the force they exert is the problem. This means the Escape does not comply with Federal Motor Vehicle Safety Standard number 118, related to power-operated windows. Ford says it isn’t aware of any accidents or injuries related to this recall, but the fault remains a risk. There are no warning signs that the window may malfunction. Quote Link to comment Share on other sites More sharing options...
rmc523 Posted June 19 Author Share Posted June 19 Ford Recalls The Fusion And Focus For Transmission Leaks That Can Lead To Fire - Autoblog The total number of affected vehicles is a sizeable 5,252 units; the breakdown is 1,489 Fusions and 3,763 Focus units. The report also says that the affected vehicles are 100% likely to have the defect, making it crucial for owners of these models to seek proper repairs or remedies from accredited dealerships. Quote Link to comment Share on other sites More sharing options...
rmc523 Posted June 22 Author Share Posted June 22 2014 Ford F-150 Recalled Over Unexpected Downshift Repair Issue The hazards: an unexpected downshift into first gear may result in a loss of vehicle control, increasing the risk of a crash. Ford is not aware of any reports of accidents or injuries related to this condition. Components: powertrain control module software Affected vehicles: select 2014 Ford F-150 pickups produced between June 19th, 2013, and December 23rd, 2014 Number of vehicles affected: 44,963 The fix: dealers will update the powertrain control module software. This will be performed at no cost to 2014 Ford F-150 owners. Quote Link to comment Share on other sites More sharing options...
Joe771476 Posted June 29 Share Posted June 29 I guess we don't know how to make planes either! FAA extends deadline for Pratt Powered 777's https://share.google/uFRYiTt5z4Zz2xfYq United returns 787's to Boeing for quality issues: https://share.google/UpLiX2dzf4UweY1e4 Quote Link to comment Share on other sites More sharing options...
rmc523 Posted June 30 Author Share Posted June 30 The “Gold Standard For New Vehicle Quality” Recalls 741,000 Roll-Away SUVs And 36,000 Flare-Flinging Broncos | Carscoops The big recall affects 2021 F-150s, 2020-2021 Explorers and Lincoln Aviators, plus 2018-2021 Expeditions and Lincoln Navigators. In total, 741,195 vehicles are involved, making this one of Ford’s larger actions of the year. Certain transmission downshifts can briefly engage the parking pawl while the vehicle is still moving due to insufficient fluid flow to the park valve, Ford says. That can damage the transmission’s parking system, leaving it unable to securely hold the vehicle in Park if the electronic parking brake isn’t applied. In that situation, the vehicle could roll away, increasing the risk of a crash. One tell-tale that a rollaway is on the cards is the possible appearance of a wrench-shaped warning light in the instrument cluster. There’s also a smaller Ford recall in the news this week involving 36,046 examples of the 2022-2026 Bronco Raptor. In these SUVs, improperly manufactured attachment holes and leftover burrs or fibers can prevent those butch-looking fender flares from fully securing during assembly. As a result, the flares can loosen and eventually detach, creating a road hazard for other drivers. Quote Link to comment Share on other sites More sharing options...
Sherminator98 Posted July 1 Share Posted July 1 10 hours ago, rmc523 said: The “Gold Standard For New Vehicle Quality” Recalls 741,000 Roll-Away SUVs And 36,000 Flare-Flinging Broncos | Carscoops The big recall affects 2021 F-150s, 2020-2021 Explorers and Lincoln Aviators, plus 2018-2021 Expeditions and Lincoln Navigators. In total, 741,195 vehicles are involved, making this one of Ford’s larger actions of the year. Certain transmission downshifts can briefly engage the parking pawl while the vehicle is still moving due to insufficient fluid flow to the park valve, Ford says. That can damage the transmission’s parking system, leaving it unable to securely hold the vehicle in Park if the electronic parking brake isn’t applied. In that situation, the vehicle could roll away, increasing the risk of a crash. One tell-tale that a rollaway is on the cards is the possible appearance of a wrench-shaped warning light in the instrument cluster. There’s also a smaller Ford recall in the news this week involving 36,046 examples of the 2022-2026 Bronco Raptor. In these SUVs, improperly manufactured attachment holes and leftover burrs or fibers can prevent those butch-looking fender flares from fully securing during assembly. As a result, the flares can loosen and eventually detach, creating a road hazard for other drivers. Not an excuse, but those are at least 5 year old products that we know have issues for the big recall and the Bronco Raptor is manufacturing defect most likely due to a bad setting for the tool. 1 Quote Link to comment Share on other sites More sharing options...
rmc523 Posted July 1 Author Share Posted July 1 10 hours ago, Sherminator98 said: Not an excuse, but those are at least 5 year old products that we know have issues for the big recall and the Bronco Raptor is manufacturing defect most likely due to a bad setting for the tool. Sure. Still a recall, but we'll see how many recalls are 2026+ products... 1 Quote Link to comment Share on other sites More sharing options...
rmc523 Posted July 6 Author Share Posted July 6 (edited) Ford Recalls 66,000 Hybrid SUVs Pedestrians May Not Hear Coming - Autoblog Ford has recalled over 66,000 hybrid SUVs for a faulty pedestrian alert system, which could pose a risk to pedestrians. The issue affects certain model years of the popular Ford Explorer and the Lincoln Nautilus. This recall is an expansion of a previous recall issued for the same thing in 2025, as the automaker’s previous fix was not effective. Over 70 warranty claims have already been submitted in relation to this problem, so here’s everything worth knowing about the new Ford recall. In a recall report published by the National Highway Traffic Safety Administration (NHTSA), Ford has traced the problem down to the following models: 2025-2027 Ford Explorer Hybrid (18,242 vehicles) 2024-2027 Lincoln Nautilus Hybrid (48,141 vehicles) Edited July 6 by rmc523 Quote Link to comment Share on other sites More sharing options...
akirby Posted July 6 Share Posted July 6 This is probably one reason Farley is trying to being back experienced engineers. Far too many recall fixes are not fixing the problem. 2 Quote Link to comment Share on other sites More sharing options...
rmc523 Posted July 7 Author Share Posted July 7 2021-2023 Ford Mustang Mach-E Recalled Over Rear Differential Issue The hazards: differential pinion shaft fracture may result in a loss of drive power, or unintended vehicle movement if the vehicle is in park without the parking brake applied, increasing the risk of a crash. Ford is not aware of any accidents or injuries related to this issue. Components: rear differential assembly Affected vehicles: select 2021-2023 Ford Mustang Mach-E models produced between March 3rd, 2020, and August 21st, 2023. Number of affected vehicles: 42,784 Quote Link to comment Share on other sites More sharing options...
rmc523 Posted July 7 Author Share Posted July 7 2024-2026 Ford Mustang Models Recalled Over Wiper And Washing System issue The defect: during certain cold temperature conditions, the windshield wipers may function only at their high-speed setting and the washing system may fail to function properly. The hazards: windshield wipers or a washing system that fails to function as intended can reduce visibility, increasing the risk of a crash. Ford is not aware of any reports of accident or injury related to this condition. Components: windshield wipers and washing system Affected vehicles: select 2024-2026 Ford Mustang models produced between September 18th, 2024, and February 2nd, 2026, as well as select 2025-2026 Mustang GTD coupes built from January 16th, 2025, to February 2nd, 2026. Number of affected vehicles: 67,842 Quote Link to comment Share on other sites More sharing options...
rmc523 Posted July 17 Author Share Posted July 17 2016-2019 Ford Explorer Recalled Over Roof Rail Cover Detachments Ford Motor Company is recalling select 2016-2019 Ford Explorer models over an issue with roof rail cover detachments. The defect: in affected vehicles, the roof rail covers may come loose and detach from the vehicle. The hazards: detached roof rail covers can create a road hazard, increasing the risk of a crash. Components: roof rail covers Affected vehicles: select 2016-2019 Ford Explorer models built at the Chicago Assembly Plant between September 19th, 2014, and March 3rd, 2019. Number of vehicles affected: 288,314 The fix: dealers will inspect the roof rail covers and as necessary, repair or replace the push-pins, rail clips, or roof rail covers, free of charge. Quote Link to comment Share on other sites More sharing options...
HotRunrGuy Posted July 17 Share Posted July 17 2 hours ago, rmc523 said: 2016-2019 Ford Explorer Recalled Over Roof Rail Cover Detachments Ford Motor Company is recalling select 2016-2019 Ford Explorer models over an issue with roof rail cover detachments. The defect: in affected vehicles, the roof rail covers may come loose and detach from the vehicle. Yeap, I remember having to buy one of those that disappeared,,,,,, HRG Quote Link to comment Share on other sites More sharing options...
rmc523 Posted July 20 Author Share Posted July 20 Ford’s Latest Explorer Recall Is For A Problem It Already Tried To Fix - Autoblog The problem was previously addressed under recall 25V393. However, that campaign involved inspecting the bezel for correct installation and replacing it only if it was damaged or missing. As it turns out, the issue was not fully resolved, leaving another 387,911 vehicles potentially affected. These include 227,520 examples of the 2020–2026 Ford Explorer produced from October 20, 2018, to June 24, 2026, as well as 160,391 examples of the 2020–2027 Lincoln Aviator built between October 19, 2018, and June 24, 2026. Ford noted that the affected vehicles were not produced in VIN order. Quote Link to comment Share on other sites More sharing options...
Sherminator98 Posted July 23 Share Posted July 23 Quote Link to comment Share on other sites More sharing options...
