Ford Recalls - 2026 Version
3 minutes ago, Sherminator98 said:
Ford Bronco Recall 26S55: 2021-2026 Bronco - Engine Compartment Wiring Harness Repair [July 23, 2026] 1784813109065-qs
So it's bad enough for new deliveries to be halted (if I'm reading it right), but to everyone that has one....good luck, hope you don't catch on fire while waiting!
I figured my fuel pump will die first (still doesn't have an ETA for a fix either lol)
Posted (edited)
At this point, I honestly don't know what recalls are open on mine.....I just wait until I get a notice there's a fix and then try to schedule something around when I need an oil change anyway.
I think I recently got a letter of a fix for one of them, but shrug.....
Edited by rmc523
Ford Explorer, Lincoln Aviator Recalled Over Unexpected Seat Recline Issue
Ford Motor Company is recalling select 2026-2027 Ford Explorer and Lincoln Aviator models due to an issue with the driver's seat.
The defect: in affected vehicles, an unoccupied driver's seat may recline unintentionally during certain scenarios, such as remote unlock or remote start.
The hazards: unexpected movement of the driver’s seat back may trap a second-row occupant, increasing the risk of injury.
Affected vehicles: select 2026-2027 Ford Explorer and Aviator SUVs produced from November 24th, 2025, to  June 27th, 2026.
Ford is not aware of any reports of accident or injury related to this condition.
Number of vehicles affected: 79,579
The fix: the remedy is currently under development.
10 minutes ago, akirby said:
Only affects an UNOCCUPIED driver's seat?  And that warrants a recall?  This is ridiculous.
Quote
If there's a small child in the back seat (which there shouldn't be if the vehicle is unattended, but...) when this happens, I could see an issue.  But, yeah, recalls are getting a little out of hand.
There’s been a few times where I’ll get out of the car with kids in it to run into a store for a moment and remote start it to keep the A/C or Heat going.
They're probably big enough to protect themselves from a seat though?
45 minutes ago, fuzzymoomoo said:
You would think but I do question their self-preservation abilities at times
I have a couple of those too.  One will be 21 next week and the other is 17.  The other one seems to have gotten all of the common sense. 😄
2 hours ago, rmc523 said:
I wonder when Ford stops with the "everything's a recall" approach and goes back to TSBs, etc.
I’ve wondered the same thing. Seems like many of Ford’s recalls would not be recalls for other OEMs.
My favorite so far is the "peeling chrome on the interior console may scratch you" recall.
I think they were required to "over recall" for a period of time as part of a penalty for not properly doing a recall in the past.
I don't think NHTSA works that way. They made a conscious decision to go back and find past problems and fix them now rather than have them continue to pop up a few at a time for the next several years.  Rip off the bandaid and get it over with.  If done right and assuming they aren't creating a lot of new problems it will pay off soon.
2021-2026 Ford F-Series Recalled Over Rearview Camera Issue
The defect: in affected vehicles equipped with the 8-inch SYNC infotainment screen, a software error may cause the rearview camera image to be obstructed by the infotainment home screen menu when the vehicle is placed in reverse. As such, these vehicles fail to comply with the requirements of Federal Motor Vehicle Safety Standard (FMVSS) number 111, "Rear Visibility."
The hazards: an obstructed rearview camera image can reduce the driver's rear visibility, increasing the risk of a crash.
Ford is not aware of any reports of accident or injury related to this issue
Components: software
Affected vehiclesselect 2021-2023 Ford F-150 units built between January 30th, 2020, and December 22nd, 2023, as well as select 2023-2026 Ford Super Duty F-250 models produced between March 16th, 2022, and June 1st, 2026.
Number of affected vehicles: 47,587
The fix: the accessory protocol interface module (APIM) software will be updated by a dealer or through an over-the-air (OTA) update, free of charge.
2023-2025 Ford Mustang Mach-E Recalled Over Glass Trim Detachments
The defect: in affected vehicles, the rear side quarter window glass trim may be improperly secured, which could cause it to detach.
The hazards: detached trim pieces can create a road hazard, increasing the risk of a crash.
Ford is not aware of any accidents or injuries related to this issue.
Components: rear side quarter window glass trim
Affected vehicles: select 2023-2025 Ford Mustang Mach-E crossovers produced between February 17th, 2023, and October 8th, 2024.
Number of affected vehicles: 86,543
The fix: dealers will inspect and replace the quarter window glass assemblies, as necessary, free of charge.
  • 5 weeks later...
2026 Ford EcoBoost Lineup Recalled Over Improperly Manufactured Pistons
Ford Motor Company is recalling select 2026 Ford Explorer, Bronco, Bronco Sport, Mustang, and Ranger models due to an issue with improperly manufactured pistons.
The defect: in affected vehicles, the engine piston domes may have been manufactured incorrectly, which can result in piston dome failure and lead to a loss of drive power.
The hazards: an unexpected loss of drive power increases the risk of a crash.
Affected vehicles: select EcoBoost-powered 2026 Ford Bronco models built between February 16th, 2026 and April 14th, 2026, Explorer SUVs produced from February 20th, 2026 and April 18th, 2026, Mustang models built from March 31st, 2026 to April 9th, 2026, Ranger pickups produced between February 21st, 2026 and April 20th, 2026, and Bronco Sport crossovers built from February 20th, 2026 to April 22nd, 2026.
Number of vehicles affected: 10,001
The fix: dealers will inspect the engine pistons and replace the engine long block, if necessary, free of charge.
2024-2026 Ford Mustang Recalled Over Wiring Harness Issue
Ford Motor Company is recalling select 2024-2026 Ford Mustang models over an issue with the wiring harness.
The defect: in affected vehicles, the engine compartment wiring harness ground connections may fracture and result in a loss of drive power, or a loss of function in the windshield washing system, headlights, air conditioning, or engine cooling fan. As such, these vehicles fail to comply with the requirements of Federal Motor Vehicle Safety Standard (FMVSS) numbers 108, "Lamps, Reflective Devices, and Associated Equipment," and 104, "Windshield Wiping and Washing Systems."
The hazards: a loss of driver power increases the risk of a crash. In addition, a loss of headlight function or windshield washing system function can reduce visibility, increasing the risk of a crash.
Components: wiring harness
Affected vehicles: select 2024-2026 Ford Mustang models produced between September 7th, 2022, and June 9th, 2026.
Number of affected vehicles: 148,663
The fix: dealers will replace the engine compartment wiring harness ground terminals, free of charge.
2023-2027 Ford F-150 Recalled Over Fuel Tank Detachment Issue
Ford Motor Company is recalling select 2023-2027 Ford F-150 models over an issue with the fuel tank straps.
The defect: in affected vehicles, the fuel tank may be improperly secured and leak fuel, or detach from the vehicle while driving.
The hazards: a detached tank can create a road hazard, increasing the risk of a crash. In addition, a fuel leak can cause an engine stall or increase the risk of a fire.
Ford is not aware of any reports of accidents or injuries related to this condition.
Components: fuel tank straps
Affected vehicles: select 2023-2027 Ford F-150 models produced between January 4th, 2023, and August 27th, 2026.
Number of vehicles affected: 223,472
The fix: dealers will inspect and replace the fuel tank straps, as necessary, free of charge.
