2028 Nautilus Refresh Spied
https://fordauthority.com/2026/03/2028-lincoln-nautilus-refresh-prototype-spotted-without-signature-lighting/?fbclid=IwdGRleAQmW9NleHRuA2FlbQIxMQBzcnRjBmFwcF9pZAo2NjI4NTY4Mzc5AAEe7jN5ue2zByoN5TscTZQmTotLSJNcMugdtOgXLMERZv9cn-Odd2N9Ar2Z_lk_aem_mefhjmj38_Yeb-4Zfsg4Ug
Would be nice if they bumped up the power a bit; curious if/how they’ll update the interior; seems harder to do with the 48” screen. Would also like to see new wheel designs.
56 minutes ago, rmc523 said:
Nice to see that they're actually moving forward with a refresh on a reasonable timeline instead of allowing it to languish.
I wish they updated the aviator more. I sat in one the other day (refresh) and while I still think it’s nice, it’s showing its age.
Agreed - while still a great looking SUV, it needed the updated rear panel to bring it in line with the rest of the lineup.  I'd assume there was too much required to rework the dash for the full width screen.
12 hours ago, joseodiaga4 said:
its me or the grille has changed, not the inside but the form of it, check how the hood ends on top of the grille vs the current model, or maybe it is just the camo
Well, usually the grille shape changes with a redesign lol.
Yes, it does appear different.  The "platform" bump on the bottom of the grille also looks wider.
Lincoln refers to that "platform" as a "plinth" for the Lincoln logo...
plinth /plĭnth/
noun
  1. A block or slab on which a pedestal, column, or statue is placed.
  2. The base block at the intersection of the baseboard and the vertical trim around an opening.
  3. A continuous course of stones supporting a wall.
But this is a Refresh, and take into account that right now all the lineup has the same design, it seems the plan is change the inside and outside of it
I'm not sure I'm understanding the problem.....
1) It's clearly not a drastically different look, and will still fall within the family look.
2) we should be happy they're keeping product fresh unlike what they've done in the past of leaving products to rot on the vine (I think this has to do with us being produced in China, which has received more consistent and thorough refreshes/redesigns
No, not a problem, I guess just surprises but it is for the reason you said, it is a product made for China so it normal a bigger refresh 😅
Hope they put more physical switches back. The loaner I had for my 30k service I couldn’t find a quick way to change temp or change the FM station.
This “put everything on touch screen” has got to stop. Soon they’ll put the “Open the door” three layers down on the touch screen.
Also the panoramic screen under the windshield is a nice novelty, but when it breaks a few years down the road, bet the replacement will not be found.
I can't speak to the radio station, but isn't the temperature permanently locked on the bottom of the center screen?  Just push the up (red) or down (blue) button....
Edited by rmc523
Not sure about the new grill pattern yet.  Would need to see the rest.  It's definitely giving me some mid century modern match stick pattern vibes.
I wonder if that means it's losing the front light bar or if there will be an optional grill with it.
The rear tail lights and the bar are not lined up I wonder if the light bar is moving down below the part that sticks out.  Currently the part that sticks out lights up.
I hope it keeps the front light bar, at least in the BL model.
Also I would like to see some features that are on the Chinese model and not in the US model
Hard to tell with the front lightbar.  Regarding the grille, the "matchsticks" are just camo.
In my 2023, I can move my hand down to the console, feel for the toggle switch and either press forward to increase or back to decrease the temp. All without searching on the screen, or looking away on the road for more than one should. Unless I couldn’t think of the correct command, voice command will set both sides the same and with my wife set differently, we don’t want them set the same temp.
Ah, so there IS a quick way to easily change the temperature (permanently docked temp on the bottom corners of the screen), you just don't like the setup vs. the physical button.
Out of curiosity, have you tried "change DRIVER temperature to X degrees", same with passenger?  Not sure if it'd work, and may have been one of the first things you've tried.....     I honestly find voice commands more annoying than they're worth - I'm sure systems are better now, but I remember in my Flex, you had to go through 3-4 voice menus to get what you want, which could be done with a button click or two.   As a result, I haven't really even tried using it in my Bronco.
  • 3 weeks later...
not sure if it is 100% accurate but according to this article the refresh Nautilus will debut at the end of the year, at least in China:
"According to the plan, the Voyager will be upgraded by the end of the year. At that time, all Lincoln's main models will be equipped with AI intelligent cabin and a new front face design."
https://k.sina.cn/article_3089293505_b822e0c102701k4n4.html
6 hours ago, lincolnt6 said:
I used Gemini to create a refresh inspired by the new Lincoln Zephyr facelift. I like it!
Looks nice indeed altough I preffer the full width headlight or would be better that the lights doesn’t go into the grille
I know it probably won’t happen but I wish they would add Yacht Club to the Nautilus.
I’m also wondering with the one off Navigator for Serena Williams was a hint at them saying customers will be able to do more customization going forward? I know there was an article that talked about that a while back.
I feel like that was always a next step for Black Label - have "recommended"/pre-set combos, and then if you want to pay more, you can choose your colors, similar to BMW's "Individual" program, or I think Mercedes has a "Manufaktur" program?
