Tinkerbell Posted December 21, 2006 Share Posted December 21, 2006 (edited) I've detected a slight intermittent miss. Then the check engine light came on but only for my drive home and not since. I took my car to the dealer and they said #5 was dead. I asked and was told the plug, wire, coil and injector was functioning right. (they tried a new plug and coil) They suspect a burnt valve or piston, or worse, but won't know unless they take off the head or remove and disassemble the engine. Has anyone heard of a like issue? Do you think a leak down test would paint a clearer picture? At a minimum I seek a second opinion but am not aware of a shop that might be right for that other then another dealer. 85K miles. Well cared for Merry Christmas to you all. Brian Edited December 21, 2006 by Tinkerbell Quote Link to comment Share on other sites More sharing options...
Hisss 99 Posted December 21, 2006 Share Posted December 21, 2006 Either a leakdown or a simple compression test would at the least confirm the loss of the cylinder if the compression is down a squirt of oil down the cylinder and compression re-test will confirm a ring vs a valve or "holed" piston. Is the coolant ok? Is it possible that the head gasket is blown? At 85K one would think that the cylinder should be ok unless the car was abused but you state that that isn't the case. Good Luck! Hisss 99 :shades: Quote Link to comment Share on other sites More sharing options...
Tinkerbell Posted December 21, 2006 Author Share Posted December 21, 2006 I need a better mechanic. Thanks Hiss. Quote Link to comment Share on other sites More sharing options...
52merc Posted December 21, 2006 Share Posted December 21, 2006 A hole in the piston would likely cause a great deal of smoke and blow by out of the PCV valve would be considerable. This would likely cause all your spark plugs to foul, not just one cylinder. If its anything really bad its probably a valve. An compression test should confirm whether you really have an issue or not. What I would like to know, is how did they "diagnose" that it was the #5 cylinder if the plug was firing and the injector is working. I think your right - find a real mechanic. Quote Link to comment Share on other sites More sharing options...
Tinkerbell Posted December 23, 2006 Author Share Posted December 23, 2006 I checked compression. 7 have around 200. #5 has 115. When I introduced oil that one went up to 150. Some times the car runs smooth. But at low RPM under a load you can tell something is not right. I think I have a big problem with my engine. Now I need the right sort of shop. Brian Quote Link to comment Share on other sites More sharing options...
Tinkerbell Posted February 10, 2007 Author Share Posted February 10, 2007 (edited) Hi folks. I sold my car. It was the valve train and it got bad on the way to the dealer to trade it in. I had to get on it one last time and that did it. I told the folks at the dealer and they didn't care. I bought an '07 Civic Si four door for my commute. Quite a change. My only mod is apt to be a short shift kit. The build of my Cobra Daytona Coupe is going well. When done I'll post here. Brian Edited February 10, 2007 by Tinkerbell Quote Link to comment Share on other sites More sharing options...
Tinkerbell Posted April 24, 2007 Author Share Posted April 24, 2007 It turns out it was the valve train. An exhaust valve was stuck open a bit. I didn't wait around to get the final result as I sold the car. Brian Quote Link to comment Share on other sites More sharing options...
