IM2HI2CU Posted January 20, 2011 Share Posted January 20, 2011 I have searched around trying to find a wiring diagram for the fuel delivery system. I have a 1985 Ford E150 with dual gas tanks. I have a Chilton Ford Pick-Up and Bronco 1976-1986 but the wiring diagram for the 1985 F150 does not match the color wires for the plug at the fuel tank switch. I have a replacement switch that was produced by Ford (Motorcraft switch E6UB-9A050-AB) and the wire connector plug (Ford D9AB-14489-JD) to be spliced into the existing wire harness coming out from the center of the dashboard. OK, here is my problem. The stock wiring connector has 5 wires going into the stock switch. The stock switch also has offset terminals so it will only go on one way. My replacement switch has 6 symmetrical terminals. The replacement wire connector has 4 wires coming out of the back of the connector switch to be spliced into the existing wiring and two of the wires double back to other terminals for a total of 6. The stock color wires are: green/red black/orange red/yellow orange green The replacement color wires: black red/yellow red/tan brown/orange Autozone lists a switch for my year that have 6 screw connections (SW48) but I wouldn’t know how to wire that switch to my stock wiring, or what terminals doubled-back to another terminal. Urgh!!!! I hope that I explained my problem with enough information. Thanks guys. Quote Link to comment Share on other sites More sharing options...
IM2HI2CU Posted February 2, 2011 Author Share Posted February 2, 2011 I grounded both gages and both peg full. Went to RS and got a switch DPDT 10A 6-pole toggle switch with center off position (#275-1533). Everything works! The additional perk is to have the central off position to turn both fuel supplies off. Oh, and it cost $4.27 including tax. Just wanted to follow up the post. Quote Link to comment Share on other sites More sharing options...
