Factory Tires
croplanman
I have bought two new f-150s and just order another in jan. Every truck i have gets the p rating tires and they fail around 25000 miles. Why won't ford let you order the LT tires without the off road package?
double chack and confirm with the dealer. I believe most models allow you to order the LT tires without the Offroad package (may require the towing package). Also some dealers with provide a credit on your P tires towards aftermarket tires. Good luck.
As Bajabobby said, check with the dealer and the ford site as I know there are additional tire options on certain trim levels and your dealer might even swap tires on arrival.
Should the LT tires come standard on an FX4? I have an new 2011 SCREW FX4 on order and am expecting the LT tires on them. But I've read on other posts that people are getting the p rating tires on them. Hopefully it will come with the LT tires. If not, I am assuming the dealer will swap the tires on arrival.
No. The standard tires on the FX4 are the P rated tires. The LT tires are an upgrade, option code: T8C and if I remember correctly $275.
  • 4 weeks later...
Same situation here. XLT screw with max tow package could not order LT rated tires without off-road package. Will likely be swapping the P rated tires shortly after purchase.
Does anyone have a 2011 with the LT tire. Are they still the Wranglers?? Do you tihink it is worth it to select this oprtion or simply get the P rateds and go for aftermarket LT tires? Thank you.
I ordered the LT's on my FX4. Yes they are still the Wranglers. They are damn good looking tire in my opinion! I have never had them on a vehicle before so I can't speak for their durability but so far I really like them. I think it's worth the upgrade price personally. You will be spending a LOT more then the $275 on aftermarket tires. I know I will be upgrading wheels & tires next year and I think for the price it's worth it for the interim. Much better then the P tires for a truck in my opinion.
BIGDKC,
Thats what I hoped to hear. Plus they are better for towing and off-road. Thank you.
three NEW F-150's???
Are you afraid that BO will outlaw trucks and make us all drive smart cars???
i am.
  • 2 weeks later...
Alot of people are really upset with the tires that come standard on the trucks!!! I am interested to see just how bad these things really end up being!
Edited by Reddragon
