cwbrak01 Posted May 31, 2011 Share Posted May 31, 2011 I have a 2006 Taurus with the 3.0 base engine, non flex fuel. The alternator was replaced with a Motorcraft re-man, idler pulley replaced with a Dayco, the tensioner assembly and pulley were replaced with the Goodyear versions and serpentine belt was replaced with the Goodyear Gatorback. Immediately after replacing the tensioner and belt the squeak is gone. In its place, however, is a nice slapping or rattling sound. The rattle only takes place when the car is in gear, at idle, and the AC is turned on or the wheel is turned. What is causing this rattle? I have a few theories. The OEM tensioner has a steel pulley and the Goodyear has a composite or plastic wheel, I was told that could be it. Another theory is that, according to the model number, the Gatorback is 85 1/2 inches long while the OEM motorcraft is just under 85 inches(the gauge on the tensioner shows at the top of the acceptabe range) thus the difference in belt length is to blame. A third theory is that the Goodyear tensioner doesnt have the plastic sleeve aroud the bolt to preven rattling. A fourth theory is that the power steering pump is getting weak, although fluid level is fine, there is no leak, and there is no whine. Interested to see what the experienced people here have to say, hopefully someone can shine some light on the problem. I'm brand new to the boar so my apologies for the long post, just wanted to provide detail. The car is a 2006 base model Taurus with 72,000 miles. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
ClutchTime Posted June 2, 2011 Share Posted June 2, 2011 I would start with getting the correct length belt just because when that belt stretches, and it will, you will no longer be in the acceptable range since it's right on the edge now. The tensioner could be jumping around, due to the belt's length, causing the noise but you should be able to see it moving while it's running if that were the case. I'd pull the belt off and turn the pulleys by hand to check for smoothness and play. Maybe there's a rough spot on one of them or a bad bearing inside. Try turning the ac compressor clutch by hand and see if it feels ok and watch it engage and disengage while running to be sure its not slipping. It may not be anything in the belt drive at all though. Usually when you turn the wheel or the A/C compressor engages,and put the car into gear, the idle will drop a small amount, this will usually cause anything loose on the exhaust to vibrate or rattle more than normal. It's hard to know what to do without actually hearing the sound but, I hope this helps. Quote Link to comment Share on other sites More sharing options...
