nothappy Posted October 29, 2012 Share Posted October 29, 2012 This has been the worst truck I have owned. The radiator was changed twice and the charge air cooler twice although it does not show here twice as I can no longer find the repair order for them. Ford did give me an 100000 mile additional warranty on the engine. Truck repairs DATE MILES REPAIR or MAINTENANCE 4/07/08 4601 seat back repair - recall Warranty Oil &filter change 6/11/08 10291 Oil & filter 10/22/08 18977 Oil & filter, fuel filters 4/06/09 29669 Oil & filter 4/09/09 29783 oil pump & seal replaced Warranty 5/15/09 32392 pcm update for white smoke problem 6/02/09 33306 replaced charge air cooler for white smoke problem Warranty 8/26/09 39891 Oil & filter, fuel filters, air filter 1/04/10 50072 Oil & filter 3/04/10 52301 replaced EGR valve, housing, EGT sensor Warranty 5/25/10 59469 Oil & filter, fuel filters, transmission oil & filter 8/23/10 65254 4 new tires $1160 8.30/12 66000 replaced right rear caliper $200 10/11/10 68496 Replaced radiator, thermostat & gasket Warranty 11/02/10 68831 Oil & filter --Replaced front crank seal Warranty for seal 6/24/11 79457 Oil & filter, fuel filters 2/07/12 88898 Balance driveshaft, change u-joints, center bearing $264 3/01/12 89798 Oil & filter 8/15/12 90000 shocks and front stabilizer shock $150 9/18/12 99049 Oil & filter 10/15/12 99403 Oil & filter, fuel filters, engine coolant, rear differential fluid $582 Tranmission fluid, upper radiator hose, hydraulic pressure transducer crankshaft pos sensor intake manifold gasket, oil pan gasket, Warranty Crankshaft oil seal, fuel pump cover, camshaft position sensor Bedplate gasket, rear cover gasket and seal, front cover gasket and oil pump cover gasket, front crank seal, intake gaskets,fuel pump gasket turbo gasket, exhaust bolts and nuts, fuel connector 10/24/12 100643 Rear driveshaft tube, tube shaft, slip yoke, u-joint, strap $401.75 Quote Link to comment Share on other sites More sharing options...
Zrullac Posted December 19, 2012 Share Posted December 19, 2012 I have the same truck and have had the radiator replaced at 35000 miles. NOT a good start for this truck. Just ordered a new F350 6.7L powerstroke. Hope this new engine fairs better. Quote Link to comment Share on other sites More sharing options...
drtkrw Posted September 21, 2013 Share Posted September 21, 2013 Also having lots of trouble with my 2008 F450. The radiator had already been replaced but the ongoing problem is the loss of power. The check engine light comes on and when you push the gas pedal the truck is bogging down and not moving. At times it shakes and I have to take my foot off the gas. It has been to the dealer 3 times and is currently there. They have said now it is the lower turbo unit. My truck has had this problem since 15k miles and only has 46k miles now. My brother had the same truck with the same issue, although he has since moved on to another vehicle. Anybody else having the loss of power problem? Quote Link to comment Share on other sites More sharing options...
