2012 Crank and NO START
Mizzouzk
Guys I am absolutely stumped on this one. I've got a 2012 ford focus se automatic with 145k miles on it and she's acting up. It all started while backing out of a parking spot, the car basically scooted and then went dead. Just battery discharge and oil pressure light illuminated. When I started her up she scooted and died in drive. Started again and then drove fine. It's gotten progressively worse and I've I do a bunch of short drives it will get to a point where it just cranks and cranks and no start. I floor the gas pedal during starts and it will "in my head" help it start again. And to keep it running once it does start I have to floor the pedal for about 15 seconds or it will stall out. The only CEL I get is a p00c6, nothing else. If I do a cold start in the am it fires up no issues.
Now I'm getting spark and I have no other codes pointing me to a sensor. The low pressure pump was replaced about 500 miles ago. I did get a p1450 code recently and replaced the vapor purge valve...I think unrelated as this happened before she was acting up. Also put on a junkyard HPFP and it didn't change the situation. Any suggestions would be GREATLY appreciated.
