bstaff Posted February 28 Share Posted February 28 2016 navigator- The driver side and both rear windows stopped working. When you hit the buttonon the driver control, a light comes on the dash that says engine running along with the door open symbol on the dash. The interior lights also flash on for a moment. The passenger side front window works as it should. The windows were working yesterday. Any ideas on where to start? Thank you in advance! Quote Link to comment Share on other sites More sharing options...
AutoEnginerd Posted April 5 Share Posted April 5 On 2/27/2025 at 11:55 PM, bstaff said: 2016 navigator- The driver side and both rear windows stopped working. When you hit the buttonon the driver control, a light comes on the dash that says engine running along with the door open symbol on the dash. The interior lights also flash on for a moment. The passenger side front window works as it should. The windows were working yesterday. Any ideas on where to start? Thank you in advance! I just replaced the window regulator in our 2016 navigator. (New post coming -ugh) It sounds like a switch issue in your driver door unless those rear windows also don’t work when you utilize the individual door switches on each of the rear doors? I still would probably start with that driver window door switch and its connector because it may also be stuck in child lock mode or something too. Quote Link to comment Share on other sites More sharing options...
