new boss mustang i would like
snooter
lets just say i will believe it when i see it..here is what i would want to see..the boss catch fire as your going down your driveway..the headlights go out at 90 mph..flame thrower type flames erupting out of the carburator.3 caskets on the nine inch rear differential to keep fluid from leaking out all over your garage floor.4 speed shift linkage that will not go from first to second gear under high torque stress load.inability to stay between the ditches (not intoxicated induced).oil spray pouring all over engine bay from cracked aluminum valve covers.inability to drive in traffic due to motor over-heating.brake malfunction (due to leaking master cylinder and or broken brake lines).constant battle with leaking water pump.above is actually truthful and is what i went thru (add many more cuss-filled wrenching nights)with my 70 boss 302 30 years ago.now what i really want is a lime green metallic with black gut with hi revving modern smallblock with no options that the chicks will instantly dig and go goo-goo over and request rides (flash-back)..seriously if the new boss just screams and can handle the twisties i am in.also at this point in my life as long as the thing starts when i turn the key i will be happy.however if ford decides to go green and embrace the tree-huggers then i am gone for good.i hope ford ceo (mulally?) can turn this company around and give us what we want and not what they (ford management) think we want (ford arrogance)
  • 1 month later...
