89cat Posted November 5, 2007 Share Posted November 5, 2007 Have a slow developing oil leak in "01 Navigator w/ 100K+ miles. Thought at first it was post oil change drip because only occational then more frequent. Changed oil with new filter still leaks. Seems to be coming from the area of filter or above but even with filter off it is difficult to see up there. IS there something typical with this model? Sendiing unit, oil cooler pump, fitting hose etc. Looking for direction before I start tearing into it. Thanks Ahead 89cat Quote Link to comment Share on other sites More sharing options...
Buzzforbrains Posted November 6, 2007 Share Posted November 6, 2007 Have a slow developing oil leak in "01 Navigator w/ 100K+ miles. Thought at first it was post oil change drip because only occational then more frequent. Changed oil with new filter still leaks. Seems to be coming from the area of filter or above but even with filter off it is difficult to see up there. IS there something typical with this model? Sendiing unit, oil cooler pump, fitting hose etc. Looking for direction before I start tearing into it. Thanks Ahead 89cat I have never heard of this. Might want to post something in flatratetechs forum. Quote Link to comment Share on other sites More sharing options...
Davew Posted November 7, 2007 Share Posted November 7, 2007 I have never heard of this. Might want to post something in flatratetechs forum. Check to see if the rubber gasket came off with your old filter. If not, double gaskets can cause the leak you describe. Quote Link to comment Share on other sites More sharing options...
